Bit like how you check a gas system for leaks. Pressure applied and soapy solution used. In this case the cyl head has cracked at the shrink band I would suggest. Try it with a Jabiru cylinder head to cylinder joint that hasn't been tensioned correctly. Nev
Guest Maj Millard
Yes that is a point where cylinder heads can crack and separate, and have done in the past. Guess that is one way to find them, other than a close visual inspection ............Maj......014_spot_on.gif.1f3bdf64e5eb969e67a583c9d350cd1f.gif
