Guest Guest
Hi, just registered as a member. :D
Although I have recently retired from the Airline Industry, I have been an LAME (Licenced Aircraft Maintenance Engineer) for almost 40 years. :D
Hopefully this site will grow nicely. :D
Guest Glenn
Welcome to the board. Thanks for your membership.
Guest Guest
No worries. :D
A long time since I was a "Newbie" anywhere. :shock:
At my age I will take it as a compliment. :lol:
Did you manage to check out those other sites?
Guest Glenn
Yep, checked them out. Thanks for posting about this board and site. Didn't know they existed.
A long time since I was a "Newbie" anywhere. At my age I will take it as a compliment.
LOL no prob.
Guest Dunny
Glenn
Whats with the Britannia 767 in your Avatar ?
Guest Glenn
Welcome to the board Dunny. The Britannia is just one of my models that I like. It's 1/100 scale and quite hard to find.
Guest Guest
Is that who you are with Dunny. 022_wink.gif.2137519eeebfc3acb3315da062b6b1c1.gif
Guest Guest
Dunny,
Nothing to be :( about, I was just curious. 022_wink.gif.2137519eeebfc3acb3315da062b6b1c1.gif
  • 3 weeks later...
Guest Chadza
I've just joined up and being a relative "forum junkie" I can say this one has great potential. Its a breath of fresh air to have a real-world dedicated aviation forum without all the wanker and BS artists on Pprune.
A bit about myself:
Studying Civil Aviation at UniSA in Adelaide, got my PPL late last year and currently have 80 hours in the logbook flying Diamond Katana's, C150's and PA28's. Soon to be going into Arrow's and a C206.
I can see you are going to be very useful here "lame"! Are you open to maintenance questions?
Chad
Guest Glenn
Hi Chad and welcome to the board. I hope to keep this board as friendly and helpful as possible.
I'm sure Lame can answer most things you throw at him.
Welcome again.
Guest Guest
Welcome. :D
Questions are no problem, but I cannot guarantee the right answer. 022_wink.gif.2137519eeebfc3acb3315da062b6b1c1.gif
Guest Chadza
thanks for the welcome guys. I came over from Aussim btw.
bah lame: it will be good to have someone with experience to get some advice from! I don't get a chance to talk to many LAME's at YPPF these days, my schedule is really get out to flying school, do a nav and then head to work/back to Uni!
Ok first question: I heard last week from a Uni Lecturer that even though PA28 engines (the engine designation escapes me) are built to handle whatever students can throw at them, they usually have to be completely rebuilt at their overhaul as the internals are stuffed. As I mostly fly the PA28 what common problems have you found with their engines?
Chad
Guest Dunny
Dont worry I'll keep a check on Lames answers.
:twisted:
Guest Guest
I know nothing about puddle jumpers. :roll:
Guest Chadza
whoops I was afraid of that! 111_oops.gif.41a64bb245dc25cbc7efb50b743e8a29.gif :P
Chad
Guest Guest
Sorry, but I have never even worked on light aircraft, or military aircraft, ONLY airliners. :roll:
Maybe someone else here can help. 092_idea.gif.47940f0a63d4c3c507771e6510e944e5.gif
Guest Ultralights
i to have only worked on Turbines and airline aircraft, but from what i understand, the engines in piper PA28 series are a Lycombing 0-320D or the 180 Hp 0-360D
the 320 and 360 are the cubic capacity of each engine, They are basically big lazy engines, that dont work too hard, alomst 6 ltr capacity and ONLY producing 180 hp!! not only that the engines are designed to be easily stripped down and rebuilt , each cylinder barrel is Bolted to the main block, and the cylinder heads are bolted to the barrels. Im not sure what the common problems would be but, being a big, low revving engine with a main bearing for every cylinder, i assume it would be able to take whatever pilot any pilot asks of it..
Guest Dunny
Probably have to be stripped for mandatory crankshaft inspections.
Hi
I have been a LAME for nearly 40 years and thinking about semi-retirement after having worked as an expat for most of my years.
Engines operating in the training environment usually end up having expensive overhauls due to shock cooling, which crack cylinders, (we are a bit high and fast, just pull the power back to idle and point the nose down, a bit of flap will help as well.NOT!!!)
Also not understanding the relationship between RPM and manifold pressure, ie pulling the RPM back before reducing power with the throttle. This puts unnecessary stress on the bottom end as well as the cylinders.
Guest Glenn
G'Day Fred and welcome aboard :D
Guest Guest
Yes, welcome aboard. :D
