Throttle idle cut off
Guest Fred Bear
Anyone else ever flown a Jab or know of one that when you pull the throttle back to idle then back a little more it cuts out (engine)? Only one Jab I have flown has done this and I wonder if there is any others out there and what causes it? It does not seem like a normal thing. On the ground, fine. Different story maybe on final.
Guest J430
Do you not check this on the ground before you leave? I guess so hence your question. Can happen on any engine I guess, but it does need setting right.Never had a problem with our at 800-850RPM. Set warm not cold of course.
J
