shafs64 Posted December 20, 2013 Posted December 20, 2013 Hay guys I am about to start flying the above aircraft. And would like to know if anyone in the forum has time on this type and. And can they give me there opinion. Shafs64
DrZoos Posted December 20, 2013 Posted December 20, 2013 No but looking forward to our club ctsl arriving in feb. Was supposed to arrive june 2012. Popular aircraft causing delays in delivery can only be a good sign,
av8vfr Posted December 20, 2013 Posted December 20, 2013 CTSW is def more of a handful due to the short coupled fuselage... CTLS is a bit more forgiving with CofG... so not as much pitch sensitivity.. However if you master a CTSW then no probs with a CTLS IMHO.. Cheers
Admin Posted December 20, 2013 Posted December 20, 2013 Shafts, as you may know I have owned 2 CTsw's and have many hours in them. I can say they don't like to land as they float so much with the lift the wings generate so make sure your speeds coming in are accurate. I use to like just letting her tell me when she was ready to simply plop on the runway after floating along till she was ready. In the air they are so helpful that you can in many situations just let go of the stick and they will come back to straight and level on their own. Coming in at 40 deg flaps is a daunting look as you are looking anymore ground than air so that needs some getting use to...I very rarely used 40 and much preferred 30 for this very reason however 40 is really good to get them down on shorter strips because of the float I previously mentioned. Like the jab, when landing keep the front wheel off the ground for as long as you can but watch out you don't scrape the tail. I the stall you can still do the evening 3 step as you still have full control over them. Hope this helps a little
shafs64 Posted December 20, 2013 Author Posted December 20, 2013 This will be odd for me. After flying the sports star that likes to land and does most things well.
Admin Posted December 20, 2013 Posted December 20, 2013 I have always said the Gazelle taught me to fly, the Jab taught me to fly an aircraft and the CTsw taught me to be a pilot!
facthunter Posted December 20, 2013 Posted December 20, 2013 IF I can fly it, it can't be too hard. It's got less vices than most. I must say I'm not a fan of the full flying tail, but look after it and don't go too fast and things should be alright. Nev
