Nose heavy isn't unstable. It makes it hard to stall and if you come in slow you haven't much elevator authority. Just keep a bit more speed on. Tail heavy will kill you quicker.
I think the rear seat is still a bit forward of the C of G range. Wouldn't be much in it. Don't take my word for it though. I've heard of strapping lead near the rear. Weight at the extremities may adversely affect spin recovery..Nev
C of G is normally half way behind the pilot seat and the rear seat, I'm in the range of 110 a 125 kg and never had a problem flying my Fisher Mk 1 for over 500 hours, I have flown strut braced and Maxairs with no problems. Awesome aircraft.
if that's that case I would be ok. as I have shed some Kgs since I started this thread.
I think the book covers it well in principle for max and min front seat weight. Nothing I say should imply acceptance of out of CG range operation. Tandem seats and fuselage fuel tanks should be regarded as more critical. Nev
I would have thought that, with each aircraft being different, a proper weight and balance should be done to calculate the proper max/min weights for each one.
A tandem two-seat glider will have a Wt & Bal placard in both cockppits detailing the Max/Min wts when flown solo and another showing the Max/Min on either seat when there is a known weight in the other seat.
The example is a Wt & Bal I did a while ago on a Puchacz that belonged to my club at the time. I have a GFA issued Wt & Bal Authority amongst other things.
Have a look at the Placards at the bottom of the page. Any aircraft can have similar loading placards generated by an authorised person.
Robert
Copy of GRI_120212_WT&BAL.pdf
Copy of GRI_120212_WT&BAL.pdfFetching info...
Some further thoughts.
All aircraft will have a maximum wt specified on the seat for structural reasons.
It may be the ability of the seat and associated mounting structure to support the load (pilot) in a heavy landing or crash. Or it may be the strength of the safety harness assembly to restrain the pilot in the same circumstances.
Referring to the example glider Wt & Bal, you will notice the placarded maximum pilot wts do not exceed 110Kg for this very reason. So, while the centre of gravity may be within the safe range with a very heavy pilot, the structure may not be able to support the weight safely.
Most gliders are designed with a max seat load of 110Kg, but a few are 115Kg and 120Kg.
The Drifter would be similar, I would expect. The designer must have factored in to the design of the structure the maximum loads on the seats. You can build something that will support a tonne on the seat, but the bloody thing would be too heavy to fly within our MTOW limit!
Does the Drifter not have a Type Data Sheet document or similar specifying Weight limits, CG position, 'G' limits, Speed limits etc? I've attached the Type Data Sheet for the Pooch as an example. I would not expect the Drifter's to be so involved 'though.
If it does, then the information will be published in that.
Hopefully I'm not boring everyone to tears! 072_teacher.gif.7912536ad0b89695f6408008328df571.gif 070_sleep.gif.1c8d367a0c12958f2106584470af404d.gif
Robert
EASA-TCDS-A.312_SZD--50--3_Puchacz-01-22032007.pdf
EASA-TCDS-A.312_SZD--50--3_Puchacz-01-22032007.pdfFetching info...
  • 1 month later...
Rastus thanks for this information. I was thinking that the extra weight on the seat in turns would stress it and the airframe.
