Just received an order of 24 NGK DR9EA plugs, all came with caps. $4.66 each.
What's the difference with 'R' in the part no?
Technical information
Resistor Spark Plugs
Resistor type spark plug’s incorporate an internal resistor to suppress ignition noise generated during sparking. The ignition noise which is often known as either electromagnetic interference (EMI) or radio frequency interference (RFI) can disrupt electronic communication signals, effecting the performance of sound systems, cellular phones, two-way radios and even engine management systems.
As EMI or RFI can also cause premature failure to other electronic components in a modern vehicle, it is important that resistor spark plugs are used to prevent this possibility.
Put simply, when a spark is formed it creates a mini-earthquake in the electronic world; the internal resistor in a spark plug filters out the noise created that may affect electrical components
I was getting interference on my microair radio with D9EA plugs so tried these. All noise went away:oh yeah:
  • Informative 2
Just go to your local mechanic. He replaces plugs all the time. Ask him for a few old NGK plugs. You might have to fish them out of the bin. Unscrew the lead connectors & you are ready to go.
Technical informationResistor Spark Plugs
HATE THEM - the resistors eventually fail open-circuit; it's an issue in cars if you do a lot of mi... er, kms; also an issue if you run single ignition...
Few pointsOriginal NGK caps are aluminium, easy to crush and damage, also tend to loosen with heat changes
Auto Wreckers can supply brass ones
What about resistor covers, they work the same way just thought might be more robust. Buying 12x might be expensive.
http://www.ngksparkplugs.com/products/performance/resistor_covers.asp?mode=nml
Resistor covers seem to work on Rotax 2-strokes, though I still won't have them on a single ignition engine - note that my Icom seems happy enough with the coax in good condition and the antennae 3m from the donk...
Personally, I LIKE an ignition that can slay an elephant at ten paces...
Answered my next query why wouldn't the 'R' ones just be the norm. (bit strange one Robert Llewelyn replying to another. What's the chances of that!)
A lot of cars use resistor ignition leads; if using both resistive leads & plugs, spark gets weak. Use resistive plugs on your lawnmwoer, they die every 20 hours or so from the vibes...
"Roses are Red, Violets are Blue, I'm schizophrenic, And so am I"...
If you head to Repco etc for bits, even filters, dont say they are for aircraft, i think they have to refuse to sell.
Tyre tube too?
Or find a friend with a Rotax, their plugs come with caps on them but don't use them. Generally have a box full of caps if they haven't throwen them away.
Jabiru.... Still dependant on a Rotax for reliability. Sorry couldnt help myself. ;-)
Any resistance in an electrical circuit causes a voltage drop and current decrease refer to ohms law E = I x R
If ignition noise is not an issue I wouldn't use them - less things that can fail.
  • Agree 3
