912 Ignition modules wanted....
Guest Maj Millard
I have a country customer who requires a 912 ignition module Part No 966 721. It is the one that has a single, 4 pin, and six pin plugs.
If you have one laying around I'd happy to hear from you..............Thanks. Maj.........024_cool.gif.7a88a3168ebd868f5549631161e2b369.gif
If anyone has any blown up ignition modules I will gladly take it off your hands…I want to open one up and see whats inside…I am pretty sure they will be easy to duplicate for a lot less than they cost to buy
  • Like 4
Guest Maj Millard
I'll see if I can dig you up a couple Mark.....both dead............Maj....
Thanks Maj….I believe they are epoxy filled but that isn't a problem now days….I saw one pulled apart a few years ago there didn't seem to be too much in them…I am sure I could build one after having a look at one…or two :)
Guest Maj Millard
Well in a nutshell they are just a big fancy CB controlled switch aren't they ?...............Maj....
Guest Andys@coffs
Yeah...I saw the US price for one of those modules at about $1100....by the time floods get involved and the US Dollar to AUD Fx rate movements I suppose its not far off having a whole Jabby overhaul done....<Runs for cover>
Not bad for what Im guessing, and presumably Mark is also guessing is a probably less than $50 0f components....assuming no specialist IC's have been made by Rotax that then makes that idea a waste of thought.....
I saw inside of one a few years ago a guy had pulled part…I am sure there was nothing special in there at all so I think it will be relatively easy to do…also will upgrade the the components if I deem it necessary to better spec ones
G'day Mark, I believe Roger Weston has pulled a module to pieces and has a circuit, Ask Danny Leach.
Is that you Tom?
I saw the one Rodger opened about 2 years ago but I believe it was a original version one ......I was chasing later models especially the new one with the softstart built in
Hi Tom, a while ago Roger gave me the circuit layout for a led light indicator for the ford air con mixer motor that you put me on to,to use for elevator trim.
I looked at it for a day or two then figured it was way above me, so Roger has kindly made one for me and he fitted it in a cute little plastic box with the led display bar protruding far enough so I only need to do the panel cutout for the led bar only.........very cool.
cheers
JimG
G'day Jimbo, the trim motor has been working for me for around 9years on the Savannah with no probs. I built my trim position indicator from a Dick Smith led level meter funway kit years ago, Dick Smith alas doesn't have that kind of thing anymore.
I remember those kits.......built a "Cricket" when I was a teen. Would chirp whenever the lights went out........Drove my sister crazy......LOL
There is a company in WA that can repair the modules @ $325 ea. sorry I will try and find their contact details and post it here. Tom
