hi. I have a comunica headset system, and I need a new headset. this system uses the telephone type connectors. I am having trouble finding a headset with the telephone type plug. if anyone has one for sale I would be very greatful, but failing that there is an adapter installed with the standard two jack plug connectors. does anyone know if a "normal" headset would work ok with the comunica system.
Guest Redair
Try Blueshed Aviation... he sells lots of headset adaptors, might be able to help.
I have two communica headsets and the unit and two PTT buttons on my trike. they are cheap as chips in the UK check out www.afors.com and ebay uk and something will turn up. Does anyone use lynx in australia?
I have a pair of headsets with the small telephone plugs. I understand they are called helicopter headsets??? I cannot check them but you are welcome to them at $10 each plus postage. If you want them and they do not work I will send back the $20. email me [email protected]
