motzartmerv Posted May 9, 2014 Posted May 9, 2014 Can anybody add any light to the reports of 2 aircraft suffering engine failures on or about the same day at Mittagong this week?
coljones Posted May 9, 2014 Posted May 9, 2014 Must be 2 rotax - 2 instances of a non-failing engine. 1
motzartmerv Posted May 9, 2014 Author Posted May 9, 2014 Its ok. I found some reports on the RAaus website. It wasnt this week it was a couple of weeks ago. Run of the mill valve seat failure etc.. Nothing new..500 hrs since overhaul. 1300 TT. 2 1
XAIRVTW Posted May 9, 2014 Posted May 9, 2014 They weren't on the same day about 3 weeks apart 2nd one was last Monday 5th. One from the Oaks the other from Wollongong both aircraft were over flying YMIG.
motzartmerv Posted May 10, 2014 Author Posted May 10, 2014 Yes, thanx Xair. Slowly getting info. As long as everybody's ok. Someone should open a Jab spare parts shop there..Make a killing! 1
motzartmerv Posted May 10, 2014 Author Posted May 10, 2014 Actually, there is already supercheap in Mittagong I believe. :) 3
AJS71 Posted May 10, 2014 Posted May 10, 2014 MM got some info on one of these, if you're interested I will enlighten you via a PM. Let me know...
XAIRVTW Posted May 10, 2014 Posted May 10, 2014 Yeah its starting to look like a Jabiru grave yard up here. All people involved are all safe. Engines are already out of both of them now. Been a interesting couple of weeks here at Mittagong one of aero club members was in the Cirrus that crashed in Lawson today.
AJS71 Posted May 10, 2014 Posted May 10, 2014 Hopefully not...looking forward to getting down to YMIG soon. In a Jabiru powered AC too!
JabSP6 Posted May 10, 2014 Posted May 10, 2014 Is there any word on the cause of the 2 jabiru engine failures? Just curious? Safe flying Andrew
AJS71 Posted May 10, 2014 Posted May 10, 2014 Come on now MM have a little faith! Hahaha But seriously, I will be...
motzartmerv Posted May 10, 2014 Author Posted May 10, 2014 Lol.. Height is your friend!!! Watch the windshear on a westerly.. Nasty.
motzartmerv Posted May 10, 2014 Author Posted May 10, 2014 Jsp6, one of the failures was a dropped valve seat I believe. No word on the second as yet.
Bruce Robbins Posted May 10, 2014 Posted May 10, 2014 Is there any word on the cause of the 2 jabiru engine failures?Just curious? Safe flying Andrew Hi Andrew, Both were failures of the valve train. First one was due to the top valve spring retainer suffering from rapid wear, then detaching, allowing the valve to drop down into the cylinder. Engine remained at idle through to touchdown. Second was due to a detached valve head, followed thirty seconds later by the engine stopping with a pretzel shaped Conrod after the valve head had smashed the piston into pieces. We were about 4 miles away from Mittagong at the time, but with sufficient height to setup for a safe dead stick landing. I don't know as yet whether the valve head detached first, or the valve stuck open and the head was then broken off by the piston. Regards, Bruce 1
motzartmerv Posted May 10, 2014 Author Posted May 10, 2014 Good job Bruce getting it down. Thanx for the info. 3
JabSP6 Posted May 10, 2014 Posted May 10, 2014 Hi Bruce Thanks for the update. I have suffered the same problem with my original motor a couple of years ago. I had the valve head break off and smash thru no 2 piston but my 6 cyl engine luckily kept running and I also made a safe landing at a nearby airfield. Glad to hear you made it safely. Can I ask what type of Jab you have? Safe Flying Andrew
Bruce Robbins Posted May 10, 2014 Posted May 10, 2014 Hi BruceThanks for the update......... Can I ask what type of Jab you have? Safe Flying Andrew It is a factory built 230, which I cross hire from the owner. 2.5 years old, hollow pushrod hydraulic motor with 480 hours, used for owner's trips and our cross country training. 1
JabSP6 Posted May 10, 2014 Posted May 10, 2014 Bruce I do like the 230's. I think I will upgrade to one of them one day. For now the SP6 is doing what I need it to do. I hope you and the owner get the plane back in the air soon? Safe flying Andrew
jeffd Posted June 8, 2014 Posted June 8, 2014 BruceI do like the 230's. I think I will upgrade to one of them one day. For now the SP6 is doing what I need it to do. I hope you and the owner get the plane back in the air soon? Safe flying Andrew hey jabsp6 is that a taildragger the sp6 just curious as how they go for something different may hav to post this in the general jab area though
