Geoff13 Posted June 22, 2014 Posted June 22, 2014 Can anyone please point me in the direction of the Specs for this aircraft. I am particularly after MTOW and empty weight. Also fuel quantity and cruise speed. Cheers Geoff13
JabSP6 Posted June 22, 2014 Posted June 22, 2014 Hi Geoff13 I have one of these aircraft and it depends who built it and what additional items have been fitted as to the weight of it. I bought mine already built and it came in at 284kgs empty and the MTOW is 500kgs. In saying that i have also seen some of the SP6's as heavy as 320kgs empty with the same MTOW. My aircraft has an 85 ltr fuel tank behind the seat. I have seen other SP's with wing tanks giving 135 ltrs but the heavier wings increased the empty weight of the aircraft. The cruise speed is a comfortable 120 kts and will generally burn around 20ltrs/hr. You have the same engine as the 230 only lessweight and drag so you should get a better cruise and fuel usage than the 230. The only downside is the carrying capacity is much less than the 230. Safe Flying JabSP6 1 1
Guest mak720 Posted July 28, 2015 Posted July 28, 2015 Hi there JabSP6, are you aware if the SP6 can be re-weighed and certified to meet 544kgs?
JabSP6 Posted August 5, 2015 Posted August 5, 2015 Mak720 I dont believe they can be registered to a higher MTOW. The original SP's with the 4 cylinder were 450KG MTOW and some of the 6 cylinders aircraft were increased to 500KG MTOW. I believe you are able to increase the 450kg aircraft to 500kg but i dont think you could go higher. It would be worth looking into this some more. I would certainly welcome the additional 44kgs. Safe Flying JabSP6
Toady Posted January 25, 2016 Posted January 25, 2016 I have a UL 500 -6 registered for 500 kg. (empty weight 296kg ) I recently asked Jabiru about uprating it to 544kg and was given a flat 'No'
Kyle Communications Posted January 25, 2016 Posted January 25, 2016 Thats only 204kg carrying capacity. Would be a 1 up only for me and full fuel and a bit of luggage
JabSP6 Posted January 25, 2016 Posted January 25, 2016 Hi Toady Unfortunately 500kgs is it for the SP range of Jabiru. 95% of my flying is on my own going to work and back each week so the weight is not a problem with full fuel. On the very odd occasion that I do take a passenger anywhere I have to reduce fuel level to stay within the MTOW. The only option to increase your MTOW is to upgrade to a bigger Jabiru. Safe Flying JabSP6
