I am working on the list of the "functions"......
Anyone got any others/extra ones:
If the stone is wet: It is RAINING.
If the stone is covered with a clear coat of water: It is ICY.
If you see the stone’s shadow on the ground: It is SUNNY.
If the stone is white on the top: It is SNOWING.
If you can’t see the stone: It is FOGGY.
If the stone is swinging on the rope: It is WINDY.
The strength of the wind will be indicated by how far from the vertical the rope is.
The direction of the wind will be indicated by reading the numbers under the stone.
(Note: The value is not fixed as different stones have different weights and so
They need calibrating before an accurate reading can be taken.)
If the stone is jumping up and down: There is an EARTHQUAKE.
If the stone is gone: There is a CYCLONE.
Ok, foggy/night.
As it is a WEATHER rock, I "erred" on the side of "if you can't see it, if is foggy" rather than night.
The ICE line needs work, I just don't know how else to describe it.
Open to thoughts.
Thanks though.
Ok, More questions:
Rainy, Foggy. That would constitute IMC.
Which other things would this apply to?
FLOOD - what aviation term would that have if it was an airport?
(Closed is obvious, but is there another more "techie" term?)
Facthuter,
Thanks.
But "Raised dust" (etc)...... I don't know how to apply that to the appearance of "the rock".
I changed the original so it is:
If you can't see it: It is NIGHT
If you can't see it from a distance: It is FOGGY.
But that is about the best I can do to include that.
NIGHT, FOGGY, IFR/IMC. (Which term is the correct?)
I am sumising that they make it IMC which forces IFR. Though "NIGHT" isn't really a weather condition.
It is supposed to be a WEATHER Rock. Nev
Yes.... So how do I "include" the dust parts of your original reply to the rock?
Just asking.
This is the newer list:
If the stone is wet: It is RAINING. *1
If the stone is under water: There is a FLOOD. *2
If the stone is warn: It is SUNNY.
If the stone is coated with ice: It is FROSTY.
If the ice is thick: It is a HEAVY FROST.
If you see the stone’s shadow on the ground: It is CLEAR. CAVOK
If the stone is white on the top: It is SNOWING. *3
If the stone is hard to see from a distance: It is FOGGY. *1
If you can’t see the stone: It is NIGHT. *1
If the stone is not hanging vertical: It is WINDY.
The direction of the wind will also be indicated by reading the numbers under the stone.
Further, if the direction is changing, then it can be taken that the wind is VARIABLE.
they need calibrating by a qualified person before any readings can be taken.)
If the stone is jumping up and down: There is an EARTHQUAKE. *2
If the stone is gone: There is a CYCLONE. *2
*1 IFR flights only permitted in IMC conditions.
*2 Airport CLOSED
*3 Please check that it is not patches of white, in which case it is more than likely to be bird $hit than snow.
If the stone is Blurry it is foggyIf you can't see the stone it is night time
If the stone is blurry, you've had too much to drink.
If you can't see the stone, you've passed out.
rgmwa
Rock Submerged >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> You've landed at the Floatplane base by mistake.
Rock hanging upwards >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Some dumb Pommie has landed and messed with it.
Rock whizzing around in circles making a "Gerzing Gerzing Gerzing " sound >>>>>>>>>>> Crocodile Dundee been making bush phone calls with it.
Rock hanging there without string - you've landed at the International Space Station by mistake.
Those persisting with this conversation have rocks in their heads. Nev
In that case they will have no problem predicting the weather will they?
Cheers Geoff13
Guest Howard Hughes
Does this help?
HH, yes, that is from what I am basing this.
I am just wanting to make it a bit more aviation themed.
