Guest Offroad4wd
Hi everyone. I am only new to the scene. I have been in lots of small aircraft and really enjoyed it. Thats what got me interested in it and I have wanted to get my licence for along time but have only just started researching it. I will apologise now if I ask any stupid questions. I look forward to learning a lot from here and starting the adventure.
Tim
Hi everyone. I am only new to the scene. I have been in lots of small aircraft and really enjoyed it. Thats what got me interested in it and I have wanted to get my licence for along time but have only just started researching it. I will apologise now if I ask any stupid questions. I look forward to learning a lot from here and starting the adventure.Tim
Welcome! Your certainly in the right spot. There are so many knowledgable people on this forum.
Guest Offroad4wd
Thanks recflyer
What sort of flying do you want to do?
Have you looked in recreational (raaus) versus ppl/rpl (General aviation aircraft) And the differences.
Guest Offroad4wd
I was looking at raa as I didn't know about the RPL until a few days ago. Now that has got my interest. I like the extra weight option ect
I also looked at the RPL, but cost wise and for enjoyment, the RAA seemed to be a better fit. Also, down the track it seems easy now to transfer the RAA over to RPL.
Guest Offroad4wd
The biggest problem I am having with the RPL at the moment is trying to find a school that can give me more info. From what I can find the RPL is not much different to the RAA in regards to couse structure, flight times ect. I could be wrong though.
Guest Offroad4wd
Someone here might be able to set me straight on that
For me to learn RPL, it would cost around $200 to $250 hour out of Parafield. With RAA, is around $135 with where I am doing this through.
Now there is quite a few differences between the 2 in regards to what you can do. ie RAA, you can not fly in controlled airspace, Max weight is 600KG, where as RPL is 1500KG Max weight and you can fly into controlled space. If you want to fly bigger aircraft, RPL to PPL is the way to go.
In terms of flying, I believe they are similar for the course structure and many of the endorsements / requirements are the same, ie VFR, aircraft control, radio, ect.
For me, I just wanted to get out and have fun without breaking the bank. If I chose RPL, I would most likely not do it because of the cost.
Not sure if you have seen this on the RA-Aus website: https://www.raa.asn.au/learn-to-fly/recreational-vs-private/
Also, if you want to convert to RPL later, it seems quite easy with minimal hours. See the RPL info here. http://www.casa.gov.au/wcmswr/_assets/main/lib100191/rr61_rpl_fs.pdf
It states:
I already hold a pilot certificate issued by RA-Aus. How do I obtain an RPL?
A pilot certificate is equivalent to an RPL. To get your RPL you need to complete an application form, and follow the instructions on the form to provide evidence of your pilot certificate, submit a recent photograph and provide appropriate proof of your identity. You also need to undertake a flight review before you can use your licence. Your new licence grants you the relevant category rating, aircraft class rating and design feature endorsements. You are also granted a recreational navigation endorsement if your pilot certificate authorises you to conduct crosscountry flights and if you meet the minimum flight times.
You are right, only real difference is the 2 hrs of instrument time. Oh, and of course the extra cost of flying the GA aircraft and the extra headache of dealing with CASA and AVMED!
Guest Offroad4wd
For me to learn RPL, it would cost around $200 to $250 hour out of Parafield. With RAA, is around $135 with where I am doing this through.Now there is quite a few differences between the 2 in regards to what you can do. ie RAA, you can not fly in controlled airspace, Max weight is 600KG, where as RPL is 1500KG Max weight and you can fly into controlled space. If you want to fly bigger aircraft, RPL to PPL is the way to go.
It states:
Thanks for that. It seems like I should start with RA-Aus and if I feel the need later go to RPL. It seems like a lot cheaper way to get started
Thanks
Tim
