Not so sure about that - some are significant.
Checkout the changes to recommended max oil pressure for hydraulic lifter engines.
Down from 76psi to 51psi
Lifter pump up has been a concern for a long while
South African agent issued an SB on this some time ago
The problem is the minimum pressure if you adjust to this low, hot engine on idle youll see alarms come on
