Russ Posted June 14, 2015 Posted June 14, 2015 would someone mind breaking down for this ol coot, what each line is telling me. R COOKTOWN (YCKN) TAF AMD YCKN 132044Z 1320/1408 12012KT 9999 SHOWERS OF LIGHT RAIN SCT020 BKN035 INTER 1320/1408 3000 SHOWERS OF MODERATE RAIN BKN018 RMK T 23 25 25 26 Q 1013 1015 1014 1012 SPECI YCKN 140000Z AUTO 13011KT 9999 // SCT014 BKN021 OVC037 24/22 Q1015 RMK RF00.0/000.2 1
pmccarthy Posted June 14, 2015 Posted June 14, 2015 As far as I know you can still translate the full briefing at http://www.anard.net/pemet/pemet.html 1
FlyingVizsla Posted June 14, 2015 Posted June 14, 2015 And on this website too - go to Menu - Resources. 1
turboplanner Posted June 14, 2015 Posted June 14, 2015 Well good on him for at least making an effort to comply. 1 1
Russ Posted June 14, 2015 Author Posted June 14, 2015 Ok......followed the "resources" option, onto naips,got area briefing............then it stalled, proceeding wasn't happing..???
ben87r Posted June 14, 2015 Posted June 14, 2015 COOKTOWN (YCKN) TAF AMD YCKN 132044Z 1320/1408 12012KT 9999 SHOWERS OF LIGHT RAIN SCT020 BKN035 INTER 1320/1408 3000 SHOWERS OF MODERATE RAIN BKN018 RMK T 23 25 25 26 Q 1013 1015 1014 1012 SPECI YCKN 140000Z AUTO 13011KT 9999 // SCT014 BKN021 OVC037 24/22 Q1015 RMK RF00.0/000.2 Ill have a crack Valid 13/06 UTC from 2000-0800hrs Winds 120 true at 12 knots- Visibility greater then 10km SHOWERS OF LIGHT RAIN Cloud Scattered 2000'AGL Broken 3500' agl Periods of deteriorating weather not more then 30 minutes (holding fuel required) valid whilst TAF is valid, of Showers of moderate rain broken 1800'agl visability 3000m (below VFR) Special weather (Below set minimums for that aerodrome and replaces the METAR and isn't a forecast but current conditions) Issued 14th UTC Zero hundred hours AUTO weather station Winds 130 true 11 knots- Visibility greater than 10km- cloud scattered 1400' agl- broken 2100'agl overcast 3700' agl Temperature 24c dew point 22c QNH 1015 Remarks No rainfall last 10 min- 0.2mm since last 9am Did I miss anything? 3 1
Birdseye Posted June 14, 2015 Posted June 14, 2015 Quote Did I miss anything? Only the forecast Temp and QNH, which IIRC are for the four x three hour periods of the TAF 1 1
Russ Posted June 14, 2015 Author Posted June 14, 2015 I've sorted my prob, have to press "control and command" together with A or C or V ....now works great, bewdy
shags_j Posted June 14, 2015 Posted June 14, 2015 Russ: I would suggest you learn to read the encoded ones. It's not that hard. Go to AIP if you can find one Gen 3.5 or if not go to the BOM website for aviation. Go Here: http://www.bom.gov.au/aviation/knowledge-centre/ Select the product you are reading and it give you the info you need to decode it. Every morning until you can read these without referring to the sheet lookup particular met products for an aerodrome (say Cooktown) and decode it using these sheets (don't cheat and use the website listed above) and you will find in a matter of a few days you will have these down pat. They really aren't hard and I recommend everyone know how to read them cause that is exactly how ATC will give it to you if you request it (somewhat) 3
SDQDI Posted June 14, 2015 Posted June 14, 2015 Ben I noticed with the cloud you listed that as AGL, is that how it is meant to be interpreted for a taf? I know in the arfor that cloud base is always amsl but I wasn't sure about the taf. Ps let me also squeeze in here the fact that I can't see any reasonable reason that forecasts can't be delivered in plain English. (Shags when listening to a forecast from you atc fellas it is closer to the interpreted version and a lot easier to understand than the written abrrieviated version) Big woopy doo if it is easy to learn, so is morse code but besides the odd (not the offensive odd just the rare odd) person with an interest in it the rest of us don't need to know it and can fly and communicate quite easily without it. IMHO the less things we have to 'interpret' the safer we will be. It would reduce the workload of the average rec pilot and maybe we would see a lot more using the proper resources and not using inferior but easier to read sources. End of rant 2 3
ben87r Posted June 14, 2015 Posted June 14, 2015 Yep, that's correct, AGL for TAF's and AMSL for ARFOR's. Make it easier for alternate requirements/ VMC minima etc. As for the presentation, the shorthand is much easier to read in flight when your under the pump, only after you have a good understanding of it tho. You can look for certain info quickly without having to read or interpret any of it. I do admit that if you aren't reading it everyday I can be confusing tho. 1
ayavner Posted June 14, 2015 Posted June 14, 2015 I thought on TAFs, isn't the wind direction in magnetic?
ben87r Posted June 14, 2015 Posted June 14, 2015 Quote I thought on TAFs, isn't the wind direction in magnetic? Na it's true north. I don't use AIP so I can't give you a reference unless you have jepps? Written is degrees true and herd is degrees magnetic. There was one exception to this and I can't remember exactly what it was but I assume it's when you copy a TAF off centre obviously it's still true 1 1
flyhi Posted June 14, 2015 Posted June 14, 2015 Quote I thought on TAFs, isn't the wind direction in magnetic? Yes you are correct. The wind direction in a TAF is magnetic.
Happyflyer Posted June 14, 2015 Posted June 14, 2015 Quote Yes you are correct. The wind direction in a TAF is magnetic. Are you sure? How about a reference? On the BOM website it says about a TAF: Wind The wind direction is given in degrees True, rounded to the nearest 10 degrees. A variable wind direction is given as VRB (used when the forecasting of a mean wind direction is not possible). The wind speed is given in knots (KT). The maximum wind gust is included, after the letter G, if it is expected to exceed the mean by 10 knots or more, e.g. 28020G30KT gives a wind direction of 280° True, with a mean speed of 20 knots, and a maximum gust of 30 knots. http://www.bom.gov.au/aviation/data/education/taf.pdf 1
ben87r Posted June 14, 2015 Posted June 14, 2015 Thanks HF! I didn't think of BOM, and don't have electronic Jepps.
nathan_c Posted June 14, 2015 Posted June 14, 2015 Quote Ps let me also squeeze in here the fact that I can't see any reasonable reason that forecasts can't be delivered in plain English. (Shags when listening to a forecast from you atc fellas it is closer to the interpreted version and a lot easier to understand than the written abrrieviated version)Big woopy doo if it is easy to learn, so is morse code but besides the odd (not the offensive odd just the rare odd) person with an interest in it the rest of us don't need to know it and can fly and communicate quite easily without it. IMHO the less things we have to 'interpret' the safer we will be. It would reduce the workload of the average rec pilot and maybe we would see a lot more using the proper resources and not using inferior but easier to read sources. End of rant Thats because when we read it out to you we are just decoding it as we read it, because its quicker and more useful to everyone than reading out the phonetics exactly as they are coded in the Taf. Having a standard format allows it to be the same every time and therefore everyone has an expectation of how its going to come out. If it wasn't coded in a certain way, the Met guy could write whatever the hell he wanted in whatever order he wanted, and I guarentee you that would end up more confusing especially if you were trying to compare two TAF's side by side to see the changes (just as an example.) As for "IMHO the less things we have to 'interpret' the safer we will be", I actually completely disagree. As shags said it will take a person a couple of days to start getting stuff down pat (for the common stuff at least. Hell sometimes even I have to look up certain decodes before I give them to a pilot just because its not common), but once you know how to read/interpret them you are going to have a far greater understanding, and appreciation of what its trying to tell you and I actually believe the more knowledge you are armed with, the safer overall you will actually be as a pilot, not the inverse as you are suggesting. My 2c anyway, cheers. 3
Happyflyer Posted June 14, 2015 Posted June 14, 2015 Quote Thanks HF! I didn't think of BOM, and don't have electronic Jepps. No worries mate. It's always a bit frustrating when someone contradicts something without a reference.
flyhi Posted June 14, 2015 Posted June 14, 2015 Quote No worries mate. It's always a bit frustrating when someone contradicts something without a reference. Thanks HF you have put me on the right track . I was mixing up TAF's with ATIS.
ayavner Posted June 14, 2015 Posted June 14, 2015 Just having a look at AIP GEN 3.5 4.4.1 - refers to ATIS, and wind is in degrees magnetic 7.4.3 - refers to AWAIS, wind in degrees magnetic which are what you "hear" as Ben87r pointed out, above. Then of course as happyflyer pointed out the others being in "True". I think i probably added 2+2 and got 5, thinking that the ATIS would be the same as someone just reading off the TAF. Great thread!
Happyflyer Posted June 14, 2015 Posted June 14, 2015 The Knowledge Centre on the BOM website is a great help for decoding TAFs and AFORs. Try to understand these forecasts each time you go flying and the format soon becomes decipherable. http://www.bom.gov.au/aviation/knowledge-centre/ 1
ben87r Posted June 14, 2015 Posted June 14, 2015 Quote thinking that the ATIS would be the same as someone just reading off the TAF. There can be further information not listed in a TAF, few examples Xwind Dwind for the duty runway, instrument or visual approach expectations, turbulence on final and a heap of others like works in progress, so an ATIS is different to a TAF. An ATIS isn't just "weather" but like the name says terminal information 1
SDQDI Posted June 14, 2015 Posted June 14, 2015 Quote I was taught: "If it's written down it's true!" That is an awesome way to remember it Powerin, although highly ironic when talking about forecasts:wink: 2
