WayneL Posted June 25, 2015 Posted June 25, 2015 Question! Does the maker of aircraft skins need to approval and or certification to supply skins for legal use on a factory made aircraft? Or...is there no difference or issues regarding the legality when used on either a kit built verses factory built aircraft? I.E. 25-xxxx rego verses 19-xxxx rego.
Flying leghorn Posted July 1, 2015 Posted July 1, 2015 Quote Question! Does the maker of aircraft skins need to approval and or certification to supply skins for legal use on a factory made aircraft? Or...is there no difference or issues regarding the legality when used on either a kit built verses factory built aircraft? I.E. 25-xxxx rego verses 19-xxxx rego.
Flying leghorn Posted July 1, 2015 Posted July 1, 2015 Quote Question! Does the maker of aircraft skins need to approval and or certification to supply skins for legal use on a factory made aircraft? Or...is there no difference or issues regarding the legality when used on either a kit built verses factory built aircraft? I.E. 25-xxxx rego verses 19-xxxx rego. HI Wayne you must be working on my road then as that's where I live ..Craig
WayneL Posted July 16, 2015 Author Posted July 16, 2015 Quote This will be interesting?. Do you mean.....an Answer to my Question....?
