Has anyone installed or had anything to do with the ecofly diesel areo engine or any other diesel areo engine? I know the Fk9 can have one factory installed, I'm building a Savannah & very curious about them.
  • Replies 72
Posted Images
Whilst the idea of a Diesel engine is interesting to reduce fuel use and load... However I wonder if the practicality is achievable in Australia with the lack of access to fuels when touring? It's hard enough getting Avgas and will be even harder to get Jet A1 in the bush.
The idea is that they can run on good quality diesel or Avtur. They could probably run on kerosene if you had to.
I personally would have thought if it could run on diesel as well as jet that the availability in the bush would have been a lot better than avgas. Diesel is found in a lot more places than reliable unleaded.
Ps Birdseye replied while I was typing.
Most vehicles out bush are diesels so I was thinking it would be rather simple to get your hands on. I read the 80hp ecofly diesel only uses 8L an hour and a savannah having 130L tank I will never need to come down anyway. The only 100hp diesel I could really find was a 2 stroke and it claims to burn around the 15L an hour mark. Is diesel powered aircraft the way of the future?
Nah, electric is the way of the future.
Maybe once somebody comes up with an efficient fuel cell, but battery technology still has some way to go.
Even though it's a Diesel engine, it's not safe to use diesel fuel in an aviation environment.
There is a very real risk of diesel fuel turning into a lump of wax when it cools.
Diesel fuel is managed to meet the geography it will be used in each month. There are 100 regions in Australia and the waxing point is changed so as to remain liquid... As I said this happen every month.
If you fuel up in a warmer month and don't use it for a couple of months or fuel up and fly south or fly high into cooler air you may find your fuel lines could be full of wax.
I'm still very doubtful of the practicality in this context.
  • Helpful 1
  • Caution 2
I never considered that. Maybe a rotax 912S is the go for me and I should stop trying to reinvent the wheel.
That's why they call it the future... 008_roflmao.gif.692a1fa1bc264885482c2a384583e343.gif
If you want to reinvent wheels consider a 912iS if you are looking for more economy. I have a regular one in the box for mine and it is hard enough to get on with fitting it, but will be very straight forward when I get back to it..
I have thought about the 912IS but just not sure if I can justify the 5k more they cost then the normal 912s. I haven't even started the build yet so I have time on my side. I'm not in a real hurry at the moment I can still fly my dad's savannah when ever I like & having an already built one to look at should make mine go together quicker when those tricky bits come along. Plus this is the second savannah we have built so that should help. I do like the idea of the 912IS though.
I was thinking of the foreseeable future.
In regard to diesel waxing, it shouldn't be an issue unless buying then flying from the extremes of climate and incorporating a bit of high altitude flying. For most recreational aviators its unlikely to be an issue.
I recently had a problem getting diesel out of my 1k liter overhead tank. The inline filter looked like it was wrapped in glad wrap.
I had bought 1k liters in January and by June it had waxed up - summer fuel is not for winter. My fuel supplier said he would fix it and turned up with 200 liters of heating oil to add to it.
That worked.
I was thinking of the foreseeable future.In regard to diesel waxing, it shouldn't be an issue unless buying then flying from the extremes of climate and incorporating a bit of high altitude flying. For most recreational aviators its unlikely to be an issue.
As an example, if you fuelled up in Darwin (Savflyer's home base) in September the Cloud Point (when waxing occurs) is 15 deg C and fly to Brisbane were diesel is managed down to 2 deg C you could have a real problem. Alternatively you take a September batch of Darwin diesel on a 25 deg day to 5000 ft you could be pressing the boundary of the fuel remaining liquid. Not forgetting that the difference between months going from summer into the winter months will make things much worse. In darwin the Cloud Point drops from 15 deg in Feb to 8 deg in just over 60 days.
Even in WA, your home base, there is 15 deg difference between Port Hedland and Perth between Feb and March, which is worse than between Darwin and Brisbane.
There is roughly only around 8-10 deg protection between cloud point and normal low ambient day temps and waxing within the same geographic areas.
I suggest that you don't need to start flying in extreme climatic conditions to expose yourself to some considerable risk.
  • Informative 2
Guest Andys@coffs
for country's the size of Singapore....for ones at the other end of the spectrum however.......
The FK9 is coming out with diesel from factory so I'm guessing they work if people are doing it!
Even FK recommend JetA1 ... in Europe diesel Cloud Point is managed differently than in Aust and they do have Arctic quality fuels, furthermore the time variations and transitions are differently managed. What they do in Europe doesn't work in Oz.
We are rapidly getting to the stage where airfields in remote areas are more likely to have a avtur supplies than avgas.
This is particularly so with the mines and Aboriginal communities up north and northwest.
Kaz
I was just reading on the Jodel forum of a bloke who recently finished a Diesel Jodel, an ecofly I believe, lives in NZ. all's well and he is very pleased with the result. I'll post his name as soon as I find it
.. a bloke who ...... lives in NZ. I'll post his name as soon as I find it
"Bro"?
  • Haha 4
Then no one has mentioned random quality of diesel even from branded outlets
Water, organic growth, general wax and over dosing of winter addtives
Tractors and 4wd generally dont mind so much but ask a rural Toyota dealer how many CRD rebuilds they have done in recent times.
As Kaz mentioned, no issues getting JA1, AVGAS is the issue.
Yes diesel is the future for conventional aircraft, once everybody catches up with the technology. Electric on the other hand it's the technology that has to catch up.
Then no one has mentioned random quality of diesel even from branded outletsWater, organic growth, general wax and over dosing of winter addtives
Toyota makes me wonder sometimes. We run a 09 landcruiser wagon and have fitted the extra water trap/filter as recommended by just about everyone but I still have to change the original fuel filter MORE often than the oil filter!! All our diesel at home here goes through a 30 micron filter before going into anything and we don't have any hassles with anything else, dad runs a Mitsubishi pajero with no problems whatsoever.
Don't get me wrong I do like the cruiser but it seems their fuel system could be a whole lot better.
Pump diesel may not be ideal for year round use but with a little care (and maybe the odd additive) it adds another option which really does improve availability in out of the way places.
