Robbo Posted July 28, 2015 Posted July 28, 2015 Hello :) I use both AvPlan & OzRunways Got a niggle about both... AvPlan data must be stored on a slow server as I need to download every piece of data for Australia and overseas most of the time the server times out and data has to be downloaded over a few days. Just installed the latest version of OzRunways and spent a few hours updating all countrys data and maps, now I cannot even open the app it just crashes. I am running an ipad air 2 on ios 8.4
djpacro Posted July 28, 2015 Posted July 28, 2015 I had a chat with Bevan at Oshkosh and explained why I had gone back to OzRunways and I'd forgotten those frustrations with AvPlan download times from a year or two ago. I now have an iPad Mini, no issues with OzRunways but I only have some of the charts. I assume you have informed both of the problems?
KRviator Posted July 28, 2015 Posted July 28, 2015 Try turning off your iPad, doing a soft reboot and letting it come back up, then go into OzRunways again and you should be right. 1
Robbo Posted July 29, 2015 Author Posted July 29, 2015 I assume you have informed both of the problems? Haven't had a chance as I only updated maps last night, so will do today :)
Robbo Posted July 29, 2015 Author Posted July 29, 2015 Try turning off your iPad, doing a soft reboot and letting it come back up, then go into OzRunways again and you should be right. How do you do a soft reebot? Don't wanna do a full reset as I have over 70 gig of map data on it. PS: When they update the app and you download it, do you lose all the map data or does it carry over to the updated app?
fly_tornado Posted July 29, 2015 Posted July 29, 2015 this is your problem right here How do you do a soft reebot?
Bevan Posted July 29, 2015 Posted July 29, 2015 Robbo, give us a call (AvPlan EFB) on 03 8370 3024 and we'll sort it all out for you 1
Robbo Posted July 29, 2015 Author Posted July 29, 2015 this is your problem right here Thought it was a different sequence than just turning it off and on, I know my other branded tablet has a soft reset that is by holding a few buttons and not simply by turning it on and off. FYI: That doesent fix it either, still crashes.
Robbo Posted July 29, 2015 Author Posted July 29, 2015 Robbo, give us a call (AvPlan EFB) on 03 8370 3024 and we'll sort it all out for you Hi Bevan, Managed to get all the maps on for Australia, so all good just took a couple of days. One other thing, how can I download the maps for other countrys? Cannot find the menu to select them.
Jaba-who Posted July 29, 2015 Posted July 29, 2015 While we have you Bevan Does avplan have a system that shows nearby traffic? I've just done a big trip with other aircraft over a week and one of the guys runs Ozrunways and it showed traffic using OzRunways all over the country. I had an idea that avplan did it as well but couldn't find out how to get it going. Any advice about that.
fatmal Posted July 29, 2015 Posted July 29, 2015 How do you do a soft reebot? Hold down the power button (on top) and the home button (on the front) for about 10 or 12 seconds - the iPad will restart. No data will be lost (I've had to do several due to dodgy apps!) mal
Robbo Posted July 29, 2015 Author Posted July 29, 2015 Hold down the power button (on top) and the home button (on the front) for about 10 or 12 seconds - the iPad will restart. No data will be lost (I've had to do several due to dodgy apps!)mal Sadly its still crashing :(
Bevan Posted July 29, 2015 Posted July 29, 2015 Robbo, which countries? Just tap on the map to download NZ or US maps (settings, data downloads)
Bevan Posted July 29, 2015 Posted July 29, 2015 Yes, AvPlan EFB will display live traffic. Turn on AvPlan Live (settings, User Settings). Then turn on traffic on the enroute (map) page (Map Settings, ADSB Traffic).
Jaba-who Posted July 29, 2015 Posted July 29, 2015 Yes, AvPlan EFB will display live traffic. Turn on AvPlan Live (settings, User Settings). Then turn on traffic on the enroute (map) page (Map Settings, ADSB Traffic). OK tried that. Nothing changes. No other aircraft activity in all of Australia shown when I do that. Do I have to do anything else? Is it only going to show traffic using ADSB out? Do I need an ADSB receiver attached for that? 1
Bevan Posted July 29, 2015 Posted July 29, 2015 We only send back aircraft within 200nm of you. If you want ADSB traffic, an external receiver would be required. We support a couple of commercial ones (iLevil2 SW and Sagetech Clarity) and an ADSB receiver based on a raspberry-pi which if you are somewhat technical you can build yourself
Jaba-who Posted July 29, 2015 Posted July 29, 2015 Ah. ok. Got that. I'll get onto a mate in cairns here and get him to turn on his and see if it works then. Ok now here's a curly one. Last week we did a trip to the Northern Territory. We flew up to Bathurst island and met a guy who flew down from further north on the island. He uses Ozrunways. I use avplan. I had no naips flight plan in. He claimed he had tracked me coming up from darwin on his Ozrunways. He said his Ozrunways identified my call sign and aircraft type when he tapped on the aircraft symbol. Are you aware if Ozrunways can cross over to identify avplan using aircraft? Or was he Bulls...ting me?
Bevan Posted July 30, 2015 Posted July 30, 2015 Sounds very unlikely. We don't share callsigns with other AvPlan users let alone other apps.
Jaba-who Posted July 30, 2015 Posted July 30, 2015 Seemed odd to me. He showed me Ozrunways running at the time on the ground and Ozrunways did definitely display aircraft call signs and type that were flying at that instant - but I suspected they were almost certainly ozrunway-using aircraft and I guess they sent that data if Ozrunways was set up to include that data on the iPad. But seemed very odd to be getting that data from a cross-app situation. He quoted my call sign but then my plane was standing in front of us so he may have just looked at the tail numbers.
Jaba-who Posted July 30, 2015 Posted July 30, 2015 I got it to work. Shows an aircraft with the numbers 9100 170 next to it. Are they altitudes and speed?
ben87r Posted July 30, 2015 Posted July 30, 2015 We don't share callsigns with other AvPlan users let alone other apps. I tell you who would be on to a winner, someone who came up with a cheap, small separate app that just broadcast position and notified by sound when another broadcaster was within XXX NM (user defined) and was able to show position on a map. Map could be simple enough, no need to be a WAC, this would solve the issue of different EFB users or, guys like myself who use an EFB for charts and plates and who don't use the flight plan options, or, to be honest only really use it when in new territory or doing an instrument approach. Also, be more likely to get everybody to use it. Could work similar to ADSB notification... Just my 2c anyways, i"mno software designer and if push came to shove, probably couldn't spell EFB...
SDQDI Posted July 30, 2015 Posted July 30, 2015 You don't need a flight plan to have ozrunways show you up, as long as you have ozrunways running and have selected to share your traffic data it will show up. As mentioned in another thread the altitude displayed on ozrunways traffic data is in feet compared to your altitude for example if you are at 1500 feet and have traffic showing up at +500 they are 500 feet above you NOT 500 agl or amsl and likewise if they are at -500 they are 500 below you. Quite handy once used to it. 1
ben87r Posted July 30, 2015 Posted July 30, 2015 When i used it the other day, first time with close traffic, it showed +055, and I was at A095, sure enough he passed 4k' below me, is this an error?
Geoff13 Posted July 30, 2015 Posted July 30, 2015 I got it to work. Shows an aircraft with the numbers 9100 170 next to it.Are they altitudes and speed? Aircraft 9100 is an A22LS Foxbat. At least it is when I plan a trip in Ozrunways. Flys out of YCAB. The one thing that I have found with the tracker is if you have your Ipad and Iphone both with the same flight plan as I often do just to have a backup. You can be flying along and it can show another aircraft very close to your location and height. It is actually yourself. Scared the crap out of me the other day. I did also track another aircraft leave Archerfield and track directly towards me last week. I adjusted my height and watch him pass above and just behind me. I may not have seen him had I not been specifically looking for him at that height and in that direction. 1
Jaba-who Posted July 30, 2015 Posted July 30, 2015 Aircraft 9100 is an A22LS Foxbat. At least it is when I plan a trip in Ozrunways. Flys out of YCAB.The one thing that I have found with the tracker is if you have your Ipad and Iphone both with the same flight plan as I often do just to have a backup. You can be flying along and it can show another aircraft very close to your location and height. It is actually yourself. Scared the crap out of me the other day. I did also track another aircraft leave Archerfield and track directly towards me last week. I adjusted my height and watch him pass above and just behind me. I may not have seen him had I not been specifically looking for him at that height and in that direction. This aircraft I was following on AVPlan Live was about 100 nm north west of Cairns. In area with sparse phone coverage at low altitudes but you get cover over 4 or 5000 ft. It was also moving pretty fast. Maybe several miles every 15 seconds of update so I suspect it was not a Foxbat. That's what made me think it was altitude and speed. Bevan said earlier that AVPlan doesn't send any identifying data to other users so I don't think it would be identifying that Foxbat. .
