I'll have to make the next batch tougher. Correct again.
Seven days are up,so here is the answer. Kit Aircraft Super Prospector.
Another seven day test. This time, Lambert Mission M108.
Aveko designed and originally produced this aircraft, which is now produced by JFM Aircraft. This one is registered as a JFM Evolution.
Yes, Jungmeister, but modified as the Lamb CJ-1.
And Roundsounds plane is a GY-80 Gardan Horizon, as djpacro said.
I sat in the backseat on a number of flights in the Horizon when I was a young lad, the gear and flap were operated by a single handle. Gear and flap were wound either up or down, you could not separate their operation. If you ever see one departing you can tell when the pilot has started retracting the gear by the pitching/rolling induced by the pilot while he winds the gear/flap up.
[ATTACH]38577[/ATTACH]
Bonus points if you can name the orange and white aircraft in the background too.
[ATTACH]38581[/ATTACH]
Stirs Playmate
Background , Luton Major ??"
You got the Luton Major!! The one in the foreground is a Stitts Payboy. I watched both of these aircraft during finally assembly at Camden when I was a young hangar rat. Managed to go for a ride in both, later in life I did a flight review for one of the Luton’s owners and had a fly of it - very Tiger Moth like to fly.
I cant find it. Looks like the wings are too close together and would interfere with each other. If so it might be a one off that stayed in the paddock!
The plane is a Kestrel Hawk. The one in the image has tricycle u/c, but the one in
has a single wheel under the fuse and outriggers, U2 style.
