diesel Posted August 7, 2015 Posted August 7, 2015 As a matter of interest with 406 beacons how many personal ones get used after a mishap. Was it set off before touchdown, after, or not at all? With fixed installation did it work? Or did something prevent that like structual damage or aerial wipeoff? Chas
Ultralights Posted August 7, 2015 Posted August 7, 2015 apparently NASA are testing the fixed automatic ELT's to see if they actually work, i think the initial report suggested 90% failed to activate on impact. so, i always carry mine in my pocket, and if i need i will activate it before i land if the engine quits.
Jaba-who Posted August 7, 2015 Posted August 7, 2015 apparently NASA are testing the fixed automatic ELT's to see if they actually work, i think the initial report suggested 90% failed to activate on impact. so, i always carry mine in my pocket, and if i need i will activate it before i land if the engine quits. I have read something similar although not quite that high. Vaguely recall it was just under 50%. But I'm not going to disagree with you on the effect that even that percentage has. The other factor ( and maybe the combination of these adds up to the 90%) is that a significant number become useless after impact. Things like the aircraft sinks or is burned and the Elt either stops functioning or the signal is attenuated enough to be useless. I agree with you. I carry mine in the door pocket next to my left hand and when wearing a life jacket over water I put it in the jacket pocket. I have a second one I bought for bushwalking and the passenger gets that when we are travelling. ( with appropriate instruction about usage and not setting off both together etc. )
Nobody Posted August 7, 2015 Posted August 7, 2015 apparently NASA are testing the fixed automatic ELT's to see if they actually work, i think the initial report suggested 90% failed to activate on impact. so, i always carry mine in my pocket, and if i need i will activate it before i land if the engine quits. The atsb report available at the link below shows the failure rate for fixed elts isn't as high as 90% but is still high. https://www.atsb.gov.au/publications/2012/ar-2012-128.aspx These days they are cheap enough to to have both a fixed and personal one.
Ultralights Posted August 7, 2015 Posted August 7, 2015 i found the ATSB report, and to correct my post, it seams about a 50% failure rate.. still, pretty abysmal for something that would be considered essential to safety.
diesel Posted August 7, 2015 Author Posted August 7, 2015 Its mandated that we have them even if we used spider tracks. Elt in pocket is great. However in recent very untidy endings they have not been used. On one bad day not long ago it was gps on cellphone that found the one on route to Albion Park. Of course the chance of cell phone coverage is also slim. Chas NZ
driftamark Posted August 8, 2015 Posted August 8, 2015 Hi all I have found that when you are involved in an out landing you are so busy flying and setting up to land that you do not find time to radlo or set of elt 1 1
