Can anyone recommend Type or brand of manometer for testing Altimeter and Airspeed indicator. Thanks
This may assist. Put food dye in the water to improve the contrast, you also need another bleed valve so as you attach the syringe the needle does not move and when inserted close this bleed valve and your readings are from 0.
Mike
Mike
Manometer.pdf
Manometer how to build EAA Sport Aviation in August 2006.doc
Manometer.pdf
Manometer.pdf
