Issued 13 August 2015
Schedule 24 Amendment to Civil Aviation Order 95.32
[1] Heading
Substitute
Exemption from provisions of the regulations under theCivil Aviation Act 1988 — weight shift controlled aeroplanes and powered parachutes
[2] Subsection 2, definition offlight radiotelephone operator licence
Omit
[3] Subsection 2, Note
Substitute
Note Definitions of some expressions used in this Order can be found in regulation 2 of CAR 1988 or the Dictionary for CASR 1998 (as provided for by subregulation 5 (2) of CAR 1988). Expressions defined in regulation 2 of CAR 1988 include (for example)agricultural operations. Expressions defined in the Dictionary for CASR 1998 include (for example)flight crew licenceandflying training area.
[4] Paragraph 3.1
Omit
with the following
Insert
with Part 61 of CASR 1998 and the following
[5] Subparagraph 3.1 (a)
Omit
4D, 5 and 7
Insert
4D and 7
[6] Subparagraph 3.1 (b)
Omit
subregulations 83 (1), (2) and (3)
Insert
subregulation 83 (1)
[7] Paragraph 5.2 (including the Note)
Substitute
5.2 In spite of paragraph 5.1, a person who makes an airborne radio transmission on an aeronautical HF frequency must be authorised to transmit using an aeronautical radio under Part 61 or Part 64 of CASR 1998.
[8] Subparagraph 7.1 (k)
Substitute
(k) the radiotelephone equipment (if any) fitted to an aeroplane must not be used by a person unless the person:
(i) for transmissions on VHF frequencies only —holdsa valid certificate, issued by the RAA or the HGFA in accordance with the appropriate Operations Manual, relating to the operation of radiotelephone equipment; or
(ii) for all transmissions — is authorised to transmit using an aeronautical radio under Part 61 or Part 64 of CASR 1998.
[9] Subparagraphs 7.3 (d) and (e)
Substitute
(d) the aeroplane is flown by the holder of a pilot licence with an aeroplane category rating:
(i) issued under Part 61 of CASR 1998; and
(ii) that allows the holder to fly inside the controlled airspace;
(e) the pilot has a valid flight review for the class rating in accordance with Part 61 of CASR 1998;
[10] Subparagraph 7.4 (a)
Substitute
(a) the pilot in command is authorised under Part 61 of CASR 1998 to do so; and
[11] Subparagraph 8.1 (d)
Omit
, under subregulation 141 (1) of CAR 1988,
______________________________________________________________________
Schedule 25 Amendment to Civil Aviation Order 95.55
[1] Heading
Substitute
Exemption from provisions of the regulations under theCivil Aviation Act 1988 — certain ultralight aeroplanes
Omit
[3] After subsection 2
Insert
Note Definitions of some expressions used in this Order can be found in regulation 2 of CAR 1988 or the Dictionary for CASR 1998 (as provided for by subregulation 5 (2) of CAR 1988). Expressions defined in regulation 2 of CAR 1988 include (for example)agricultural operationsandcertificate of approval.
[4] Paragraph 3.1
Omit
with the following
Insert
Omit
4C, 4D and 5
Insert
4C and 4D
[6] Paragraph 3.1 (b)
Substitute
(b) regulation 37;
[7] Paragraph 3.1 ©
Omit
Insert
[8] Paragraph 5.2 (including the Note)
Substitute
[9] Subparagraph 7.1 (l)
Substitute
(l) the radiotelephone equipment (if any) fitted to an aeroplane must not be used by a person unless the person:
(i) for transmissions on VHF frequencies only —holdsa valid certificate, issued by the RAA in accordance with the RAA Operations Manual, relating to the operation of radiotelephone equipment; or
(ii) for all transmissions, but subject to paragraph 5.2 — is authorised to transmit using an aeronautical radio under Part 61 or Part 64 of CASR 1998.
[10] Subparagraphs 7.3 (d) and (e)
Substitute
[11] Subparagraph 7.4 (a)
Substitute
[12] Subparagraph 8.1 (d)
Omit
[13] Paragraph 9.5, Note
Omit
Hi Ada
As far as I am aware if you have an RPL with navs and controlled traffic area endorsements you are legally able to operate in controlled airspace.
