Kyle Communications Posted September 13, 2015 Posted September 13, 2015 Yes the fork was around the wrong way...it is of course the right way around now
Steve L Posted September 13, 2015 Posted September 13, 2015 Hi Lyndon, I used the Carslisle tyres and with 6 psi in them they stand 18.5 inches tall. A lot of trouble, expense And weight to go to for an extra 2 inches in height if you import them. Carslisle's are available here. Steve 1
Lyndon Posted September 13, 2015 Author Posted September 13, 2015 Thanks for all the replies. Carlisles are available here ???. Who has them. Is that size ok to run in front. A member here has two for sale. If they suit the front I probably agree all three the same light and not to dear Lyndon
Steve L Posted September 13, 2015 Posted September 13, 2015 Call Fred 02 69214981 . Aircraft spruce has them and also 2 available on this site.
Lyndon Posted September 13, 2015 Author Posted September 13, 2015 Does anyone know the weight of the carslisiles tyres ???. Does it fit the front fork width wise Lyndon
Kyle Communications Posted September 13, 2015 Posted September 13, 2015 They will not fit the front fork...you have to make a new fork or use 600/6 condors
Lyndon Posted September 13, 2015 Author Posted September 13, 2015 Ta. Weight condors vs the Carlisle tyres ??
Kyle Communications Posted September 13, 2015 Posted September 13, 2015 The condors are lighter cant tell you the actual weights but some searching on the net will find it
Lyndon Posted September 13, 2015 Author Posted September 13, 2015 That's surprising. I thought a golf cart tyre would be very light. I will have a Google. Thanks Lyndon
fallowdeer Posted September 13, 2015 Posted September 13, 2015 Perhaps analyse your intended landing places. Soft? Rough? Combinations of those parameters? Think of it in terms of tyre print on the ground and radius of tyres for handling rougher surfaces and that might help your decision. Larger tyres better for rolling over stuff but downsides too; weight, drag, and higher loading on axles and other associated structures. All a compromise like everything else. Peter
rick morawski Posted September 13, 2015 Posted September 13, 2015 Does anyone know the weight of the carslisiles tyres ???.Does it fit the front fork width wise Lyndon Hi Lyndon, You can get a factory made wide fork and axle (ask for the strength mod axle) to fit the Carlyle tyres from Reg at Aerokits, he usually has them in stock. Rick
Lyndon Posted September 13, 2015 Author Posted September 13, 2015 Yep I'm onto to wide fork. Be nice not to spend that money if not needed. I have bought it for a rough strip plane. A bit of speed does not concern me. Of course weight does. The Cart tyres seem very light. So maybe spend the 250 or so on the fork and axle. Then three cart tyres and carry a spare tube. I have three in the kit I'm not using nd I'm sure will work in a bind. 1
Lyndon Posted September 13, 2015 Author Posted September 13, 2015 I would think most of my landing is rough and Rocky. Not really beaches and sand in south Australia
eightyknots Posted September 16, 2015 Posted September 16, 2015 mine, Desser 850-6. got them here http://www.desser.com/Aircraft-Tires-and-Tubes/850-6-4-PLY.asp Hi LyndonI imported these direct from Desser Tire and Rubber in the states, their service was great. The mains are Aero Classic brand, only for LSA and experimental and so can't be put on a certified GA plane. The Condor though is OK for that and came with a release form, not that it is needed for microlight here. Like lots of things in life the mains aren't quite 21" but close enough. Landed price with tubes was$900NZD, was a lot cheaper than trying to source them here. Yep, probably cost me a few knots but didn't get this frame to go fast. Did add a few pounds but well, well, worth it for strip work. The aircraft has been landed on gravel bars and the like and I also gleaned a bit more prop clearance from the change. Peter Hi Ultralights and Fallowdeer, any idea what the "velocity cost" is for those tyres over the ICP standards ones?
eightyknots Posted September 16, 2015 Posted September 16, 2015 mine, Desser 850-6. got them here http://www.desser.com/Aircraft-Tires-and-Tubes/850-6-4-PLY.asp That's first time I have seen the new colour scheme, U/L: reminiscent of the old
Lyndon Posted September 16, 2015 Author Posted September 16, 2015 I tried buying those dessers for 109 bucks. Looks like they don't ship overseas and won't answer emails. Spruce don't have them. Just the polished jobs for 229. Lyndon
eightyknots Posted September 17, 2015 Posted September 17, 2015 I tried buying those dessers for 109 bucks. Looks like they don't ship overseas and won't answer emails.Spruce don't have them. Just the polished jobs for 229. Lyndon Are there any suppliers Down Under?
fallowdeer Posted September 17, 2015 Posted September 17, 2015 I got Desser to ship to the NZ Post depot they run in the states, is there an equivalent you can use? Bound to have lost some speed with all that extra drag but if you were worried about that then you'd be flying some other type.
Lyndon Posted September 17, 2015 Author Posted September 17, 2015 You mean you got them sent to a third party that sends it to me .??? Lyndon
eightyknots Posted September 17, 2015 Posted September 17, 2015 Enzed Post has a system where you can by North American products and have them sent to a quasi address in the United States. Then, for a fee, NZ Post sends the item(s) to New Zealand. Everyone who uses their system is issued a unique address so there are no mix ups. For instance, Joe Bloggs in Te Puke won't end up with fallowdeer's new aircraft tyres (tires if they are from the USA). It is a really good service because there are quite a few traders in North America who say "we don't ship overseas". This isn't an issue because NZ Post operates an address in the United States on behalf of all their registered customers.
Lyndon Posted September 17, 2015 Author Posted September 17, 2015 Ship to does it. 175 for both tyres. Not sure if it is us or aud
microman Posted September 17, 2015 Posted September 17, 2015 Enzed Post has a system where you can by North American products and have them sent to a quasi address in the United States. Then, for a fee, NZ Post sends the item(s) to New Zealand. Everyone who uses their system is issued a unique address so there are no mix ups. For instance, Joe Bloggs in Te Puke won't end up with fallowdeer's new aircraft tyres (tires if they are from the USA).It is a really good service because there are quite a few traders in North America who say "we don't ship overseas". This isn't an issue because NZ Post operates an address in the United States on behalf of all their registered customers. The operation is called YouShop and it is brilliant - not only does it solve the problem of traders who wont ship overseas - it also means that you can often take advantage of "free postage in the continental United States" which is often available. You also avoid the huge shipping costs charged by many US traders as YouShop only charges nominal fees to ship to NZ. If the value of your goods is over $400 YouShop will charge GST which means that you dont then have the problem of customs clearance when the goods arrive in NZ. All in all a very good solution and one I have used many times. Especially good for importing aircraft parts which seems to be a regular occurrence! 1
Ultralights Posted September 17, 2015 Posted September 17, 2015 most traders who dont ship overseas do it for reason of free trade agreements, if their product can be sold here, (usually for a lot more) then they will not ship to that country, expecting you to buy it here (for a lot more) as for the speed penalty, i have no idea at the moment, as i have yet to fly with them fitted. havnt worked on the Savvy for a few months now, waiting for the summer uni holidays to get back into it.. but i am pretty sure there wont be a speed penalty, well a negligible one, as the Savvy is overpowered with 100 Hp up front, but im certain it will be a fuel burn penalty. of at least 1 Ltr/hour. if not more. Before the slick dessers, i was planning on 18L/Hr with the 600X6 Condors. at 87 Kts 5100Rpm. with the 850's im assuming 19 to 20 at the same RPM and similar speed. but test flying after all the mods will get the true figures. 1
Lyndon Posted September 18, 2015 Author Posted September 18, 2015 All sorted. Bought from Desser free shipping to Compton in CA. I have them in a container full of cars. Delivery directly to Adelaide. Lyndon
eightyknots Posted September 18, 2015 Posted September 18, 2015 All sorted. Bought from Desser free shipping to Compton in CA. I have them in a container full of cars. Delivery directly to Adelaide.Lyndon Well done. I am glad you have it all worked out.
