That's what I'm thinking. There is a curve or bend in part for sure
  • Caution 1
Heres mine,,, its wings... you attached them when wings sit on fuselage.
It is attached to the inboard end of the wing nose skin, covers the gap between the wing and windscreen.
I think it will show up in the chapter on "wing assembly on fuselage."
Rick
Edit: Skee answered while I was typing
  • 1 month later...
First thought is leading edge Wings against front window, thats only place i can position them, looks a little bit diff than mine but you have a newer model.This list made my sorting SO much easier, I bought 20 boxes and sorted everything by chapter.
That is an excellent idea Skee!
Yes prime one side BUT while you are there prime the other side too because when you sit in the plane you are going to spend more time looking out through the windscreen at the back of them than you are going to spend looking at the outer side.
