lyle janke Posted October 11, 2015 Posted October 11, 2015 hi all who has written to jabiru seeking permission to replace VDO guages & fit the temp monitoring system fromMGL is there a std letter form that can be used or is the format free form what detail is required?? any help suggestions appreciated thanks lyle
planesmaker Posted October 11, 2015 Posted October 11, 2015 Why not just call jabiru and ask? They are very helpful. It is not a problem if you want to change to a full CHT/EGT system, just ask what they require, simple.
DrZoos Posted October 11, 2015 Posted October 11, 2015 Also check out https://www.raa.asn.au/marap-faqs/ in case it affects you. MARAP is designed to assist any member with an aircraft that was accepted under a European Type Certificate as well as an Australian Type Certificate.
Roscoe Posted October 12, 2015 Posted October 12, 2015 Jabiru have told me they need drawings of the proposed installation and details of who is doing the work. They then need to approve it. I have the MGL Gauge and probes ready to go into my Jab but decided to have Jabiru do the work to save any hassle!
Roscoe Posted October 12, 2015 Posted October 12, 2015 I should have mentioned mine is a Factory build LSA, not sure about other types.
