I was having a chat with an instructor/owner of a Tecnam P92 with a 912UL, about RPM settings and while reading our respective 912 manuals / POH we found out that we have a different Reduction Ratio.
On the Savannah I have the option 2.43:1 (Same like the 912ULS) and the Tecnam has the 2.27:1 standard reduction ratio.
What difference this made to the engine ?
Does this has an impact on the propeller to select for the aircraft (type, pitch, ...) ?
Does this change the way the engine is tuned ?
Thanks for sharing your knowledge.
Cheers,
Xavier
Very interesting question.....
Off the top of my head, I'm thinking one would be pitched slightly differently but ultimately give similar performance.
In makes no difference to the engine but will change the propellor selection.
For the same power setting on the engine the 2.43 gearbox will have a slower propellor speed than the 2.27 gearbox but a higher torque. In general you would want a longer propellor blade on the one that turns slower.
