Any opinion and recommendations , I am thinking about Trig 21 but it is a bit expensive I fly close to CTA quite often and think would be usefull and also traffic avoidance system in other aircrafts will pick me up.
A mode c might be ok but would have some restrictions.
"If fitting a new transponder Post 6 February 14 a mode S transponder is required unless the aircraft is restricted to operations Below A100 in Class G and Class D. In such areas a mode C transponder is acceptable."
http://www.airservicesaustralia.com/projects/ads-b/mode-s-transponders-ads-b-and-vfr-aircraft/
What this means is that you couldn't go into Class E airspace of which there is quite a lot.
Then just buy the cheapest mode s get it done if your not looking into integrating it to your efis, then you need special equipment.
A mode c might be ok but would have some restrictions."If fitting a new transponder Post 6 February 14 a mode S transponder is required unless the aircraft is restricted to operations Below A100 in Class G and Class D. In such areas a mode C transponder is acceptable."
But class E is not anywhere below 8500 ft if I recall ( and in a lot of places is into the flight levels) so if you don't ever go that high.
