Wonder what this guy does for an encore?
Hey Frank - is not that the way you cut the sugar cane up in Deeral from memory ?
Best SSCBD
Hmm the video won't play for me. Maybe because I don't have the bookface?
I have Facebook & it does not play for me either
Try this link!
Please tell me if it plays.Frank.
Try this link!
Your link still doesn't play for me Frank But the one corvairkr put up did.
He wouldn't want to leaf his rotation any longer or he would've needed floats!
Have the bookface I do not. Play for me it did.
Are you using an IPad Marty? Franks links won't play for me but the YouTube one that corvairkr put up works fine. Maybe Frank's links are not compatible with the iPad?
Nah, crappy old Dell laptop.
Frank's link worked for me. I wonder if that silly act was staged as obviously he had enough spare oompf to manoeuver through the trees. JUST. That's been around for a while, and I recollect it was high and warm, if my memory serves me well. Nev
Not for me. Only the other one of taking off through the trees.
I believe this incident is discussed at length by the pilot. I can't remember where I saw it but I think it was hot and high long grass and I seem to recall no flaps? Can't quite see clip well enough on my phone. I will see if I can find a link later.
I thought it was staged, a silly dangerous stunt, probably only put full power on at the last second, notice it climbed out after it got airborne.
It was discussed at length by the very experienced female CFI pilot a few years back.
She had dropped the aircraft off a few months earlier for a annual and as she had another aircraft, told the LAME there was no hurry.
She knew it normally lacked power but once she was on the down hill run she knew somerhing was wrong. But the hill was too steep to abort.
Back at her home airfield she found the problem. The LAME had refitted a throttle linkage to the wrong hole in a bellcrank and that reduced the travel of the throttle. She refitted the lincage to the right hole in the bellcrank, which gave her full throttle again and returned to the LAME next day to get the "fix" signed off.
Could happen, but why wouldn't the LAME check that the throttle hit the idle stop and the full throttle position, as well . It's no different in principle to checking controls full and in correct sense. Also a power check (revs) as soon as possible after full throttle applied. That was a pretty close call.. Nev
Long focal length = short depth of field, always enhances the drama. Like the cross-wind landing videos shot down the runway where the aircraft barely appears to move forwards, much more dramatic.
