farri Posted January 3, 2016 Share Posted January 3, 2016 Wonder what this guy does for an encore? Frank. Link to comment Share on other sites More sharing options...
SSCBD Posted January 3, 2016 Share Posted January 3, 2016 Wonder what this guy does for an encore? Hey Frank - is not that the way you cut the sugar cane up in Deeral from memory ? Best SSCBD 1 Link to comment Share on other sites More sharing options...
cooperplace Posted January 3, 2016 Share Posted January 3, 2016 change his underwear? Link to comment Share on other sites More sharing options...
SDQDI Posted January 3, 2016 Share Posted January 3, 2016 Hmm the video won't play for me. Maybe because I don't have the bookface? 1 Link to comment Share on other sites More sharing options...
Kununurra Posted January 3, 2016 Share Posted January 3, 2016 Hmm the video won't play for me. Maybe because I don't have the bookface? I have Facebook & it does not play for me either Link to comment Share on other sites More sharing options...
Kiwi303 Posted January 3, 2016 Share Posted January 3, 2016 Must be pretty overloaded Link to comment Share on other sites More sharing options...
farri Posted January 3, 2016 Author Share Posted January 3, 2016 Hmm the video won't play for me. Maybe because I don't have the bookface? Try this link! Please tell me if it plays.Frank. Link to comment Share on other sites More sharing options...
corvairkr Posted January 3, 2016 Share Posted January 3, 2016 2 1 Link to comment Share on other sites More sharing options...
SDQDI Posted January 4, 2016 Share Posted January 4, 2016 Try this link! Your link still doesn't play for me Frank But the one corvairkr put up did. He wouldn't want to leaf his rotation any longer or he would've needed floats! 1 Link to comment Share on other sites More sharing options...
biggles Posted January 4, 2016 Share Posted January 4, 2016 Nah , no go Frank ...... Bob 1 Link to comment Share on other sites More sharing options...
Marty_d Posted January 5, 2016 Share Posted January 5, 2016 Hmm the video won't play for me. Maybe because I don't have the bookface? Have the bookface I do not. Play for me it did. Link to comment Share on other sites More sharing options...
SDQDI Posted January 5, 2016 Share Posted January 5, 2016 Have the bookface I do not. Play for me it did. Are you using an IPad Marty? Franks links won't play for me but the YouTube one that corvairkr put up works fine. Maybe Frank's links are not compatible with the iPad? 1 Link to comment Share on other sites More sharing options...
Marty_d Posted January 5, 2016 Share Posted January 5, 2016 Are you using an IPad Marty? Franks links won't play for me but the YouTube one that corvairkr put up works fine. Maybe Frank's links are not compatible with the iPad? Nah, crappy old Dell laptop. Link to comment Share on other sites More sharing options...
Kiwi303 Posted January 5, 2016 Share Posted January 5, 2016 Can't be much crappier than mine... 2008 model... Both links work. Link to comment Share on other sites More sharing options...
flying dog Posted January 12, 2016 Share Posted January 12, 2016 Not for me. Only the other one of taking off through the trees. Link to comment Share on other sites More sharing options...
facthunter Posted January 12, 2016 Share Posted January 12, 2016 Frank's link worked for me. I wonder if that silly act was staged as obviously he had enough spare oompf to manoeuver through the trees. JUST. That's been around for a while, and I recollect it was high and warm, if my memory serves me well. Nev Link to comment Share on other sites More sharing options...
octave Posted January 12, 2016 Share Posted January 12, 2016 Not for me. Only the other one of taking off through the trees. I believe this incident is discussed at length by the pilot. I can't remember where I saw it but I think it was hot and high long grass and I seem to recall no flaps? Can't quite see clip well enough on my phone. I will see if I can find a link later. Link to comment Share on other sites More sharing options...
Teckair Posted January 12, 2016 Share Posted January 12, 2016 I thought it was staged, a silly dangerous stunt, probably only put full power on at the last second, notice it climbed out after it got airborne. Link to comment Share on other sites More sharing options...
RetiredRacer Posted January 12, 2016 Share Posted January 12, 2016 It was discussed at length by the very experienced female CFI pilot a few years back. She had dropped the aircraft off a few months earlier for a annual and as she had another aircraft, told the LAME there was no hurry. She knew it normally lacked power but once she was on the down hill run she knew somerhing was wrong. But the hill was too steep to abort. Back at her home airfield she found the problem. The LAME had refitted a throttle linkage to the wrong hole in a bellcrank and that reduced the travel of the throttle. She refitted the lincage to the right hole in the bellcrank, which gave her full throttle again and returned to the LAME next day to get the "fix" signed off. Link to comment Share on other sites More sharing options...
facthunter Posted January 12, 2016 Share Posted January 12, 2016 Could happen, but why wouldn't the LAME check that the throttle hit the idle stop and the full throttle position, as well . It's no different in principle to checking controls full and in correct sense. Also a power check (revs) as soon as possible after full throttle applied. That was a pretty close call.. Nev Link to comment Share on other sites More sharing options...
octave Posted January 13, 2016 Share Posted January 13, 2016 This link includes a comment from the pilot https://www.backcountrypilot.org/forum/pucker-factor-in-a-stinson-7857 1 Link to comment Share on other sites More sharing options...
Gnarly Gnu Posted January 14, 2016 Share Posted January 14, 2016 Long focal length = short depth of field, always enhances the drama. Like the cross-wind landing videos shot down the runway where the aircraft barely appears to move forwards, much more dramatic. Link to comment Share on other sites More sharing options...
