BLA82 Posted February 2, 2016 Posted February 2, 2016 hi guys, Just wondering if anyone who frequents Archerfield knows of a engine failure yesterday. I only live about 4Ks as the crow flies from the airfield and yesterday about 10am saw a 172 fly over. Just as it went overhead it splutterd through out a big pile of black smoke then stopped. I heard it start again shortly afterwards but was running like crap. I did notice it make a beeline for the field. Just interested to know. 1 1
BLA82 Posted February 4, 2016 Author Posted February 4, 2016 What could be a cause of what happened. I.e large amount of black smoke then stop. Then on restart running really rough. Would that be a mixture issue being to rich? 1
Pearo Posted February 4, 2016 Posted February 4, 2016 Meh; not Jabiru, not care. The forum owner was concerned about off topic responses recently, this is the type of response that should be stopped. If you have nothing of value to contribute to a serious matter, then keep your trap shut. This is one of the biggest problems with RAAus, or at least a perceived problem from those of us outside of RAAus looking to become involved. BLA82, I think you will find any engine failure will be a routine reportable matter, so keep an eye on the ATSB reports. 1 1 1 1
bexrbetter Posted February 4, 2016 Posted February 4, 2016 If you have nothing of value to contribute to a serious matter, then keep your trap shut. 学习瑜伽!! 瑜伽很放松!!!! 瑜伽很不错!!!!!!!!!!!! What could be a cause of what happened. I.e large amount of black smoke then stop. Then on restart running really rough. Would that be a mixture issue being to rich? The obvious one sounds like flooding, fuel heating up and shaken causes it to suddenly pressurise while unable to vent fast enough or carby floats faulty, or choke being left on or being applied for whatever reason. Either choke has been turned off again or pressure has relieved itself, engine restarted but plugs a bit clogged up. Could be ignition failure, but excessive black smoke makes that doubtful. 1
Roundsounds Posted February 4, 2016 Posted February 4, 2016 or choke being left on or being applied for whatever reason. Either choke has been turned off again the last Cessna 172 I flew didn't have a choke, is this a new option?
bexrbetter Posted February 5, 2016 Posted February 5, 2016 the last Cessna 172 I flew didn't have a choke, is this a new option?
facthunter Posted February 5, 2016 Posted February 5, 2016 Most likely carb ice. That can make the mixture rich and engine falter. Nev 1 1
shafs64 Posted February 5, 2016 Posted February 5, 2016 unless you know the aircraft its hard to know, what was the rego? it could of been a 97 model thats when they changed over to the fuel injected model.
