Blue Max oil is a premium oil recommended for Two Stroke engines, Hirth engines in particular, from Hirth website:
"Typical benefits you can expect when using BlueMax 100:1 oil:
  • Less smoke
  • Ratios to 100:1
  • Less oily mess from the exhaust system
  • Engine life increased
  • 100% mineral based,none of the unfavorable attributes of synthetic oil, no solvents added as in 50:1 oils
  • Less carbon build up than 50:1 oils"
So you use less oil. It is expensive, I have not investigated the shipping costs of oil but I expect that they would be expensive too. I guess that it would be over $25/litre plus GST and that is with very little profit margin for the effort. I personally believe that it is not worth the effort. Anyone got any thoughts on this?
  • Caution 1
N
Blue Max oil is a premium oil recommended for Two Stroke engines, Hirth engines in particular, from Hirth website:"Typical benefits you can expect when using BlueMax 100:1 oil:
  • Less smoke
  • Ratios to 100:1
Never heard of this, but you can't go wrong using Oil recommended by the Engine Msnufacturer.
Is it suitable with engines with a pump? 100/1 isn't much oil. I've used Valvoline Racing two stroke which is mineral based, and know of plenty of others who have used it , with no problems. PENNZOIL USA have an oil they are game to recommend for aircraft, having gone to the trouble of developing and testing it for that specific use. Nev
