DGL Fox Posted April 6, 2016 Posted April 6, 2016 The small vent flap on the passenger side of the canopy (tinted not clear) has broken and I am finding it very difficult to find one at a reasonable price, would anyone have any ideas where I could get one from apart from Europe, maybe someone building an aircraft has one left over or someone is wrecking a SportStar, any help here would be appreciated. David
Nobody Posted April 6, 2016 Posted April 6, 2016 I think that what you have is a mecaplex vent. They are pretty standard on most glider canopies. They are expensive. The companies website is here: http://www.mecaplex.ch/default.asp?l=en But this US website lists parts... http://wingsandwheels.com/aircraft-parts/canopies.html
DGL Fox Posted April 6, 2016 Author Posted April 6, 2016 I think that what you have is a mecaplex vent. They are pretty standard on most glider canopies. They are expensive.The companies website is here: http://www.mecaplex.ch/default.asp?l=en But this US website lists parts... http://wingsandwheels.com/aircraft-parts/canopies.html Thanks Nobody, I had a close look at the picture, it looks very similar but I don't think it is that same, it seems to have a through bolt where mine has 2 small screws 1 top and 1 bottom and yes they are expensive that's for sure, I really don't understand why ??? David
Robbo Posted April 6, 2016 Posted April 6, 2016 Could you get one made up from a plastic moulding business?
DGL Fox Posted April 6, 2016 Author Posted April 6, 2016 Could you get one made up from a plastic moulding business? Robbo yes that thought crossed my mind, I have the pilot side one I could use as a template but I don't know any company here that I could contact? I wonder about the price to run a one off... David
Robbo Posted April 6, 2016 Posted April 6, 2016 Robbo yes that thought crossed my mind, I have the pilot side one I could use as a template but I don't know any company here that I could contact? I wonder about the price to run a one off...David Maybe try these guys? http://www.aircraftplastics.com.au http://www.aerospaceplastic.com.au http://www.aeroplastics.com.au
DGL Fox Posted April 6, 2016 Author Posted April 6, 2016 Maybe try these guys?http://www.aircraftplastics.com.au http://www.aerospaceplastic.com.au http://www.aeroplastics.com.au Thanks I will have a look.. David
Robbo Posted April 6, 2016 Posted April 6, 2016 Thanks I will have a look..David No problems mate, I will keep my feelers open for you.
Mick Posted April 6, 2016 Posted April 6, 2016 David let us know if you manage to source these at a reasonable price. Like yours my Sportstar is in use in a school and these vents seem to be a weakness and get broken. No-one will ever look after your aircraft like you would yourself.
DGL Fox Posted April 6, 2016 Author Posted April 6, 2016 David let us know if you manage to source these at a reasonable price. Like yours my Sportstar is in use in a school and these vents seem to be a weakness and get broken. No-one will ever look after your aircraft like you would yourself. Hi Mike, Yes they are weakness, although the pilots side is ok but the passenger side was broken and then I repaired it and now broken again...guess who the heavy handed person that sits in that seat???? I have told him...please side the window open first before attempting to open the flap...now you think the ha hum.. instructor would realize you need to do this first...now not pointing the finger mind you but hey...if I can find one and I replace it I am going to fit a warning sticker above the sliding window so then there are no excuses..."OPEN THE BLOODY WINDOW FIRST BEFORE OPENING THE FLAP VENT" The cheapest genuine one I have found is for around $240 just for the little flap....must be made of gold Mike... I will keep you informed if I find anything cheaper.... David
Guest Howard Hughes Posted April 7, 2016 Posted April 7, 2016 yes they are expensive that's for sure, I really don't understand why ??? If it's attached to an aircraft, you always add two zeros! The perspex sunvisor on an aircraft I used to fly was $3000, engineers had one made up at local perspex place for $30, the tinting never was as good as the original, but I'm not sure it was worth the extra $2970!
OZJohn Posted April 7, 2016 Posted April 7, 2016 I replaced the one on passenger side with one without the pop out part - just a straight slide. The pop out part is just too complicated for passengers. 1
DGL Fox Posted April 7, 2016 Author Posted April 7, 2016 I replaced the one on passenger side with one without the pop out part - just a straight slide.The pop out part is just too complicated for passengers. Yes OzJohn I was going to glue the flap back in permanently but when it broke off again it must fell off to the outside and never to been seen again so I really don't even have the flap to glue back in sorry to say.... David
BJFly Posted April 7, 2016 Posted April 7, 2016 Windows and doors sound like such a hassle, invest in a Drifter 1 1 3
Blueadventures Posted April 7, 2016 Posted April 7, 2016 Yes OzJohn I was going to glue the flap back in permanently but when it broke off again it must fell off to the outside and never to been seen again so I really don't even have the flap to glue back in sorry to say.... David Hi David have a look on the GFA (Gliding Federation Australia) webb site they have a list of approved repairers. Phone around and one of them may have a solution / supply or fix. Cheers Mike 1
DGL Fox Posted April 7, 2016 Author Posted April 7, 2016 Hi David have a look on the GFA (Gliding Federation Australia) webb site they have a list of approved repairers. Phone around and one of them may have a solution / supply or fix.Cheers Mike Yes thanks Mike, Just called a guy called Joe, he has them but he won't separate the small flap from the whole window vent unfortunately although I can understand that, he wants $500 for the whole thing but I don't need the whole window vent, I also talked to Garry Morgan but he makes his own so no good there, anyway I will keep looking. David 1
Blueadventures Posted April 7, 2016 Posted April 7, 2016 Yes thanks Mike, Just called a guy called Joe, he has them but he won't separate the small flap from the whole window vent unfortunately although I can understand that, he wants $500 for the whole thing but I don't need the whole window vent, I also talked to Garry Morgan but he makes his own so no good there, anyway I will keep looking.David Hi David Can't promise anything but I may have a similar slide salvaged in my collection of treasures (wife says its all rubbish) that may suit what your chasing. I know its a rectangular opening one and also have the two perspex slide rails; but don't remember if its still got the little opening. I recall it was intact. When I get back ashore Friday night. I'll dig it out and let you know. If its suitable you can have the part FOC. Cheers Mike
DGL Fox Posted April 7, 2016 Author Posted April 7, 2016 Hi DavidCan't promise anything but I may have a similar slide salvaged in my collection of treasures (wife says its all rubbish) that may suit what your chasing. I know its a rectangular opening one and also have the two perspex slide rails; but don't remember if its still got the little opening. I recall it was intact. When I get back ashore Friday night. I'll dig it out and let you know. If its suitable you can have the part FOC. Cheers Mike Fantastic Mike, lets hope it is the right one, thanks mate. David Have you thought of making your own? Very difficult Geoff as the canopy has a curve in it and the little flap I am looking for has rebated edges and a very slight curve, I just wouldn't have the tools for make it and after talking to Garry Morgan this afternoon and listening to what he had to do to make his I think it would be to much for me to make... David 1
Blueadventures Posted April 8, 2016 Posted April 8, 2016 Fantastic Mike, lets hope it is the right one, thanks mate.David Very difficult Geoff as the canopy has a curve in it and the little flap I am looking for has rebated edges and a very slight curve, I just wouldn't have the tools for make it and after talking to Garry Morgan this afternoon and listening to what he had to do to make his I think it would be to much for me to make... David Hi David The one I have has no small vent flap. Must be an older type and is from a glider canopy. Regards Mike
DGL Fox Posted April 8, 2016 Author Posted April 8, 2016 Hi DavidThe one I have has no small vent flap. Must be an older type and is from a glider canopy. Regards Mike Ok thanks Mike for letting me know, I will keep looking... David
