1 hour ago, facthunter said:
You can change hands. Long term, flying a variety of planes is beneficial to the way you fly. You become more versatile and adaptive. Better.  Nev
Long term probably, but in the short term I would try to get 50 hours all on one type.
Different types of controls, swapping hands all slow you down when you are first learning.
You also end up paying for more hours.
That's an "Intuative" answer. In Practice it might work out differently. 50 Hours on a Basic type?  Unnecessarily restrictive IMHO. Don't get in a rut where anything different  throws you. Landings in the same plane can be different. Don't do anything by numbers.. Fly to the conditions. . An aeroplane at max Wt. is a lot different to when it's light. Nev
exactly. i have flown a yellow xair. a red xair and now an orange one.
  • Haha 6
Yes, I'm not looking for a career in flying. I already have an aircraft that I expect to keep for some time and considering I'm already on the wrong side of 70 I'm not likely to own many more (unless I break this one). So far I've had the Evektor Harmony that I enjoyed flying, then the Bristell for a few days while the Harmony engine was replaced, then the dramatic change to the high wing Jabiru J160 and then the J170 once its engine overhaul was done and after all that I'll be into my Evektor Sportstar for my Xcountry navigation and prop endorsement. I don't want any more variety. If I end up with a different plane then I'll pay for a few familiarization flights.
On 17/04/2025 at 8:28 PM, Moneybox said:
I ended up swapping planes from the Jabiru J160 to the J170. It's a nicer plane but I'm not wishing to change planes, I just want to get consistency in my handling of the aircraft and these changes don't help.
I'm told I must keep hold of the joystick at all times during the flight but with all other controls apart from the throttle in the centre I find it difficult. The yellow arrow indicates the position of the Flap control that I must operate with my left hand while scooting down the runway between Touch and Go. Anyway I'm finished with 2.4hs solo now until possibly June sometime.
i actually felt more comfortable in jabirus than tecnams.   i like the manual trim.
in the tecnam because the electric trim is so slow your halfway around the circuit still trying to sort it out .
admittedly i don't get enough regular flying to remain current.
same plan as me. get the rpc then get into my ac for the rest.
i can fly the xair no problem but not allowed to train in it because of raaus  rules forcing us into flying school aircraft.
I find the Jabiru needs very little trim while in the circuits. It doesn't seem to load the joystick up near as much as the Harmony. If you fail to trim the Harmony stick can be very heavy. I'm happy that my Sportstar has manual Trim and Flaps.
" familiarisation flights " .
Not so good in a single seater , I thought of going  from training wheel at the front,
to tail dragging in the same  model Hummelbird ,
just swapping the maim mounts to the other side.
But never got that far.
spacesailor
An aside to the above .
I sold my No., two build to a fellow forumite he can build as a TD or nosewheel,
As the doubler has been added at the rear end .
It could also end up an BEV .
spacesailor
