Anyone know the latest progress on this? Dated 9 March 2016 by ATSB.
Issue: AR-2013-107-SI-01Through-bolt failures in Jabiru engines
Number: AR-2013-107-SI-01
Description: AR-2013-107-SI-01:Thicker 7/16 inch diameter through-bolts, fitted to newer Jabiru engines and some retro-fitted engines, have had limited service to date to confirm early indications that they reduce this risk. Retro-fitting engines with thicker through-bolts has only been recommended for aircraft involved in flight training by JSB031 issue 3. Most light ...
Who it affects: Owners and operators of aircraft powered by Jabiru engines
Issue owner: Jabiru Aircraft Pty Ltd
Operation affected: Aviation: General aviation
Date, status, type
Date: 09 Mar 2016
Status: Safety action pending
Type: Recommendation
Recommendation
