Just received new email from Jabiru
To the Jabiru Fleet,
Updates – Keep up with the latest information
Revision 9 of the Jabiru Overhaul Manual (JEM0001-9) is now available to download from the Jabiru website at the following link:-
http://jabiru.net.au/Manuals/Engine/JEM0001-9_Overhaul_Manual.pdf
The updates in the revised manual are outlined below :-
Oil specification changed (was MIL-L-22851 now obsolete) to SAE J-1899
Changes to Torque setting table made (Table 9)
Additions to Top End Overhaul Mandatory replacement item table (section 5.3)
Additions to Mandatory Replacement Parts Table (section 12.1)
Add Crankshaft friction test procedure (section 4.4.2)
Update to part history tables (section 13)
Remove modified circlip pliars from Figure 21
Clarify distributor shaft procedure (section 7.8.6)
Remove alternator dimension from Figure 144
Add laminated pole plates (Figure 146)
‘Generic’ Torque settings removed (Table 9)
Note to install stud bolts with Loctite 263 added, no longer 620 (section 7.2.1)
Fuel pump assembly revision (section 7.7.2)
Add part in trouble shooting (section 8.5) regarding zero leak-downs when cold
Revise rocker bush installation (section 5.11.8 and Figure 98)
Kind Regards
Leigh Cooper
Aircraft Services & Registration
JABIRU AIRCRAFT PTY LTD
PO Box 5792
Bundaberg West Qld 4670
Ph: 07 41551778
Fax: 07 41552669
Email: [email protected]
www.jabiru.net.au
www.facebook.com/JabiruAircraft
  • Informative 3
