rhtrudder Posted June 1, 2016 Posted June 1, 2016 Anyone used the Synchromate 11 , electronic gadget rather than vac gauges , read about them in eaa yank Mag , seems they are more accurate , I have a set of the tube type ,carbmate, they seem to stick and hard to get right.
Downunder Posted June 1, 2016 Posted June 1, 2016 I have the carbmate with the LED lights. I have not found it difficult to use but trying to get your engine perfectly balanced on the finest setting (0.5) can be bloody hard. I think if you can get it "green" on the next setting (1.0) then it's all good!! 1
Yenn Posted June 2, 2016 Posted June 2, 2016 why would anything electronic be better than the manometer type alternatives. It has an extra thing to go wrong, break down. Simplify for better outcomes.
facthunter Posted June 2, 2016 Posted June 2, 2016 You need a restriction in the tubes to damp out the pulses if you are measuring direct pressure, by another method than a column of liquid. Nev
rhtrudder Posted June 2, 2016 Author Posted June 2, 2016 The Rotax.com crowd gave it a good review, anyway I've ordered one through a mate who is in the trade so I hope it works as good as they say.
Captaincoop Posted June 4, 2016 Posted June 4, 2016 The Rotax.com crowd gave it a good review, anyway I've ordered one through a mate who is in the trade so I hope it works as good as they say. Yes it does
skippydiesel Posted June 21, 2016 Posted June 21, 2016 I bought an el cheapo twin carburetor pneumatic/vacuum balancer from a motor bike shop in Liverpool (NSW). Consists of two Borden tube type vacuum gauges mounted on a panel. Pointers can be adjusted/zeroed, using a small flat screw driver. Also supplied with in line adjustable pulse restriction/damping taps. Only modification I have made was to purchase sufficient vacuum tube to enable me to sit in cockpit & read gauges, as I manipulate the engine rpm. Simple safe & easy to use. Works very well
