Blueadventures Posted July 9, 2016 Posted July 9, 2016 What tool can be used for pushing out the molex type ignition pins (in thi case the mag / ign male pin) in the electrical harness. I redid on of mine and used a narrow screw driver but would like to get a propper tool for the tool box. Cheers Mike
mnewbery Posted July 9, 2016 Posted July 9, 2016 You mean like a molex manufactured pin inserting tool? 1 1
Blueadventures Posted July 9, 2016 Author Posted July 9, 2016 You mean like a molex manufactured pin inserting tool? Hi Mnewbery. Not sure I see a lot of the round pin tools but the rotax connector pins are a solid flat pin. when looking at then front on about 2mm wide and 1.2mm thick. I'll ring Floods on monday about availability. Just asking about any options out there. I got mine out OK but looking at getting a propper tool for future. Cheers Mike 1
mnewbery Posted July 9, 2016 Posted July 9, 2016 http://www.farnell.com/datasheets/1724104.pdf?_ga=1.50713632.805734507.1468053438 1 1
Blueadventures Posted July 9, 2016 Author Posted July 9, 2016 http://www.farnell.com/datasheets/1724104.pdf?_ga=1.50713632.805734507.1468053438 Thanks Trying to confirm the correct pin and therefore the right tool. I have 4 bits of info from when I crimped the pin and grommet as the Rotax maintenance misses this info as they in recent years upgraded the ign connection from a bullet crimp fitting to the molex type and this requires that the ign switch wires are crimped including a grommet. In the info I sourced refers to a diagram of a 'Hazet' tool with the ref 05813. I also looked in the Califorian Power Systems catalog and I can find the part number but not listing of price or availability. On Monday I'll give Floods a call as I'll get a tool to enhance my special tools. Do you know if the tool in the link is for round or the squarish / flat pins? Thanks for you info. Best Regards Mike 1
Blueadventures Posted July 9, 2016 Author Posted July 9, 2016 Diagram says the flat end of the tool is 1.4mm wide Hi Thanks. The actual pin is on the attached. I'll try and email the pin suppliers and ask what tools are used to extract the pins. The tool you have the link for looks about right. (I guess Rotax may be about $200.) Thanks Mike Doc2.doc Doc2.doc Doc2.doc
Kyle Communications Posted July 9, 2016 Posted July 9, 2016 I use a piece of brass tubing the right size. You can get it from model hobby stores..its a K&S brand they come in 300 mm long. You just need to flatted the outside grab pins at the side and push then flat. Then a small piece of wire up the inside of the tube to push them out...a lot cheaper than the correct tool 1 1
Blueadventures Posted July 10, 2016 Author Posted July 10, 2016 Thanks Mark, I'll do that for the round pins. Will the same work for the squarish pins of the rotax (new style) plugs that are on the ignition CDI's . I had to check one of my to grounf via the ign switch ones on Saturday. Got it out OK but want to get a propper style tool in my kit. Regards Mike 1
Kyle Communications Posted July 10, 2016 Posted July 10, 2016 so long as the brass tube can push in the tabs (keepers) that come out the side then you can literally use anything. Its just the sizing. If it is the wrong size just fill the tube with solder and use a drill...maybe a number drill to get the right size hole. All these pin removers are the same really they just push the keepers in so the pin pops out. You can spend a lot of money on pin removers. I got sick of it years ago in my business I ended up making most of them. I find the main one I use seems to fit most connectors 1 1
Kyle Communications Posted July 10, 2016 Posted July 10, 2016 For square pins just squeeze the tube into a square in the vise..Can take some fiddling but once its done you have it forever 1
Blueadventures Posted February 21 Author Posted February 21 (edited) I made up two pin removal tools for the Rotax 912 ignition module connectors. I had used round pins and small Jewlery flat blade screw drivers in the past but after doing a 912 install this week I used a ford type removal tool for removing the old engines soft start and mag pins, very easy with the chisel shaped end to the flat tool. Being a rain again day, over the rain and heaps more on its way this week, I made two tools using the left over off cut of the s/s from car windshield wiper blades as very strong and flied the sides down to the 1.4mm width as in Mnewbery's attachment (thanks for the info was very helpful) above and placed some epoxy metal to form a handle. Edited February 21 by Blueadventures 1 2
Kyle Communications Posted February 22 Posted February 22 I just use a jewelers screwdriver or similar. Anything that has a small point is good. 1
onetrack Posted February 22 Posted February 22 eBay Aviation Supplies is your friend for this kind of stuff! 😄 https://www.ebay.com.au/sch/i.html?_nkw=electrical+pin+tools 1 1 1
Blueadventures Posted February 22 Author Posted February 22 10 hours ago, onetrack said: eBay Aviation Supplies is your friend for this kind of stuff! 😄 https://www.ebay.com.au/sch/i.html?_nkw=electrical+pin+tools Agree, bought a similar set a few days ago; just made the two so I have one in my electrical repair tools kit and one in my small spares kit on board. Easy enough to make up and the shape works a treat. 1 1
Moneybox Posted February 25 Posted February 25 Some automotive windscreen wiper inserts have a small SS strip inserted into either side of the rubber. It's a very thin rigid metal strip about 3x1mm I think without going out and looking for one. Very handy for this sort of job. 1
Blueadventures Posted February 25 Author Posted February 25 38 minutes ago, Moneybox said: Some automotive windscreen wiper inserts have a small SS strip inserted into either side of the rubber. It's a very thin rigid metal strip about 3x1mm I think without going out and looking for one. Very handy for this sort of job. Yep, exactly what I used, filed width down to 1.4mm. as above one in my electrical connector crimp box and one in tools etc on board. I carry two pins and gromets (no weight to them) as have assisted with mags not stopping Rotax's due to broken or poor crimp in the connect tor that allows for an open circuit. Just handy. 1
