planedriver Posted July 24, 2016 Posted July 24, 2016 Also, if it is a Jab (or similar) HOW are you going to open the door while still flying? Many years ago I had a wolf-whistle for the girls fitted to my car which worked from the engine manifold, and was operated by pulling a wire which passed through the firewall. Maybe this could help?
flying dog Posted July 24, 2016 Posted July 24, 2016 Many years ago I had a wolf-whistle for the girls fitted to my car which worked from the engine manifold, and was operated by pulling a wire which passed through the firewall. Maybe this could help? Please excuse my ignorance, but I have to ask: which worked from the engine manifold So HOW will this work with a EFATO? Someone has to ask. 1
planedriver Posted July 24, 2016 Posted July 24, 2016 It's all a matter of good timing to give the wire a yank before the motor carks it. A bit of practice helps:victory:
flying dog Posted July 24, 2016 Posted July 24, 2016 Well......... I shall hold judgement on that. If you climb out of an airport, and get to 1000 feet and have an engine failure, pulling the wire isn't really going to make much difference for the people on the GROUND. What am I missing? If you are talking about JUST after take off, then it is a whole different kettle. Most planes don't turn back (don't go there asking) and so go ahead. Vis, people in that area will be used to planes going over. On the given example, the planes USUALLY take off making a lot of noise. This becomes normal. So, if you are in that area, and are hearing a plane taking off and suddenly it stops or splutters, I think you would notice the "deviation from the normal" and look. But what do I know? 1
Birdseye Posted July 25, 2016 Posted July 25, 2016 Surely just open the little window and shout "FORE". 2
Nobody Posted July 25, 2016 Posted July 25, 2016 In an engine failure situation any pilot trying to find a horn switch, wire to pull or window latch to shout "fore" out of is far more likely to botch the emergency situation, stall and spin in. Keep it simple guys. Airspeed, Landing Area, Restart, secure the engine/aircraft. (or whatever version of this you have been taught) Do you think that the glider pilot in the video posted on this site a few days ago would have handled the situation as well as he did if he was reaching for a horn?
SDQDI Posted July 25, 2016 Posted July 25, 2016 In 99% of forced landings it won't be an issue Nobody and I agree that that method is perfect BUT if you have to do a forced landing on a busy beach for example then I think trying to dodge people would be more hazardous than flicking a switch so that they can dodge you. Obviously not the sort of thing you want to be fiddling with on a very late final but I still think it could have a place. Of course it will be AFTER the aviate step but if put in with the communicate part (the least important step!) I think it would be fine.
Icarus Posted July 27, 2016 Posted July 27, 2016 Those bicycle air horns work well. I had one on a mtn bike. wonder if they would burst at altitude If landing on busy golf course , probably should try to approach from the hole end. They will see you coming then. 2
facthunter Posted July 27, 2016 Posted July 27, 2016 That way you might get your landing down to a tee. Nev 3
alf jessup Posted July 27, 2016 Posted July 27, 2016 Just clip a tree on the way down, I'm sure they will hear you coming, as if we are going to have time to toot a horn, I'm sure there will be more important things to concentrate on than finding the thing and blowing it Maybe all light aircraft manufactures can fit whistles on the airframe, you won't hear them while the engine is running but you might when it's silent Pipe dreams 2
Icarus Posted July 27, 2016 Posted July 27, 2016 as if we are going to have time to toot a horn How long does it take to toot a horn? If there a people in the way would you not find 2 seconds to push a button to save their lives?
alf jessup Posted July 27, 2016 Posted July 27, 2016 How long does it take to toot a horn?If there a people in the way would you not find 2 seconds to push a button to save their lives? If there was a nice red horn button installed somewhere in the panel that might be feasible to do But having a can a compressed air horn can floating around in the back seat/ luggage compartment then trying to find it wouldn't be feasible unless of course you want to spend all your flying life with the can between your legs, then you have the issue of opening a window/ canopy still while trying to maintain control In the history of aviation the amount of people killed by an aircraft hitting them is minute compared to the amount of pilots losing control in an emergency situation Each to their own opinion I guess
facthunter Posted July 27, 2016 Posted July 27, 2016 IF your engine's out you should concentrate on landing safely as the absolute priority. You would be better checking things like seat belt fastened and TIGHT. This is a bit of a brain fart. You don't know where animals will go when you startle them. Not much point at blowing it at height I would think and you are losing height pretty fast . Don't bend the plane and injure yourself. It may ignite so think about getting out of it quickly. Nev
Jabiru Phil Posted July 28, 2016 Posted July 28, 2016 I installed a horn from a ford twin spinner on my 125 Honda some years ago. Great for mustering in scrubby paddocks. They don't make them like that nowadays PHIL.
pmccarthy Posted July 28, 2016 Posted July 28, 2016 If there was a nice red horn button installed somewhere in the panel that might be feasible to doBut having a can a compressed air horn can floating around in the back seat/ luggage compartment then trying to find it wouldn't be feasible unless of course you want to spend all your flying life with the can between your legs, then you have the issue of opening a window/ canopy still while trying to maintain control In the history of aviation the amount of people killed by an aircraft hitting them is minute compared to the amount of pilots losing control in an emergency situation Each to their own opinion I guess Having a horn between your legs could be distracting when flying.
alf jessup Posted July 28, 2016 Posted July 28, 2016 Having a horn between your legs could be distracting when flying. Correct pmmcarthy hence why I mentioned it and said can instead of horn, didn't take long did it lol
facthunter Posted July 28, 2016 Posted July 28, 2016 Gives you something to blame your crook landings on. What are you thinking of? FEAR overides sex , or else your genes would have gone extinct years ago. Nev
