Frankus1aust Posted August 1, 2016 Author Posted August 1, 2016 Quote The variable pitch prop was around for a short while,,, Main advantage at cruise above say 120 knots and would certainly help on take off. I didn't see much understanding of things like checking that the setting of the fine pitch stops permitted flight at a speed well above stall speed, say 1.3% Vs without over revving the engine. If they fail it's usually into fine pitch. EXPENSIVE and more MASS. No one's forced to fit them. Could be a safety issueI'm not against turbo prop engines and even bypass jet, They are generally more reliable than piston engines. Thirsty ? Yep and most likely to remain so. Nev In the future. with the improved ceramic coatings becoming more available we'll see them on car turbos. From there it is only a short jump to the hot end of a small gas turbine. You could imagine a small GA/RA turboprop running on kero or diesel all be it a bit thirsty. The slow part will be certification. I'm wondering if anybody is working on this now or maybe it's not worth the efforts in the existing market?
facthunter Posted August 1, 2016 Posted August 1, 2016 I think you could forget certification. For our purposes it shouldn't be necessary if you restrict it's operations a bit A good turbocharger is potentially a jet engine. Nev 1
GraemeK Posted August 15, 2016 Posted August 15, 2016 G'day Frank and belated welcome! Good to catch up at the BBQ last Sunday. 1
