sandman Posted July 30, 2016 Posted July 30, 2016 How can you tell the difference, apart from the number on the jets itself as they look identical. I have a 45 idler jet and a 55 idler jet and they look identical.
spacesailor Posted August 1, 2016 Posted August 1, 2016 Try the old "gas axe" cleaning needles, they're still around, But be very gentle or your 45 will end-up 65. spacesailor
facthunter Posted August 1, 2016 Posted August 1, 2016 The difference is the number and the size of the hole. Hopefully the relationship is constant because it regulates the flow. Cleaning it with a piece of wire isn't wise. Generally compressed air does the job and look through it with a good pair of glasses or magnifying glass should confirm no gunk in there. Nev
sandman Posted August 1, 2016 Author Posted August 1, 2016 I had idler jets #50 in my 582 with very little difference from the 55's but now have put the 45's in and idle is up a bit but will reduce the idle speed, with the idle speed screw, idle is not as lump which is good.
Guest 172M Posted August 7, 2016 Posted August 7, 2016 Here you go. Bing 54 carburetor jetting, Bing 54 carburetors jet chart for Rotax aircraft engines.
