farri Posted September 15, 2016 Posted September 15, 2016 New Wing Design Reduces Emissions and Fuel Consumption by 50%
Bruce Tuncks Posted September 16, 2016 Posted September 16, 2016 Wow they have finally seen a Jabiru and they are copying it... good move I say. 2
Yenn Posted September 16, 2016 Posted September 16, 2016 It looks as if this is a return to the Cessna type wing, which has drag from the wing / strut / fuselage connections, but the strut looks as if it may deliver lift. Back to the biplane? I wonder where they got those weights from. The wing looks to be a very high proportion of gross weight. maybe it includes the engines and fuel.
Peter Anson Posted September 16, 2016 Posted September 16, 2016 They obviously need the strut because the wing is so thin that they can't get sufficient strength with a cantilever. Thinner wing = less fuel capacity, but that's OK if you are saving fuel. I bet a lot of work went into the strut-to-wing joint. Probably not trying to get lift off the strut so much as reduce drag. 1
