mnewbery Posted December 9, 2016 Posted December 9, 2016 Electric Extra Sets Climb Record - AVweb flash Article 1000kg sent 10,000m into the sky. That's just shy of 100 Megajoules not accounting for drag. Bet it came down as a glider 1 1
mnewbery Posted December 9, 2016 Author Posted December 9, 2016 Edit: Because the motor design is brushless direct current (BLDC) it is possible to have a regenerative capability while descending. This was not mentioned 1
rankamateur Posted December 10, 2016 Posted December 10, 2016 Edit: Because the motor design is brushless direct current (BLDC) it is possible to have a regenerative capability while descending. This was not mentioned I am guessing that a prop designed and tuned for a record climb is not going to be tuned for regeneration as well, and where is the point once the record has been set anyway? 1
facthunter Posted December 10, 2016 Posted December 10, 2016 You would still get significant power recovery. Enough to do manoeuvering and a normal approach at the lower levels. 8% of what you used to get up there would be plenty. Nev
