One of these was operated by a company which made a film using one of those really big Cine-Max cameras. It came into Camden for servicing a few years ago.
Seen from a distance, the Aircam is reminiscent of a 1920s Handley-Page airliner.
This link leads to side and plan elevations: Scheme Designers - Custom designed aircraft paint schemes for all types of aircraft
OME
Ther was one at last Avalon Air show... also seen vid of someone water skiing behind an aircam in flight.. found picIMG_0227.JPG.00fa8ed8af049d6dd8133548d0d63f7f.JPG
Bill Morgan, Up here in the Tolga area of the Atherton Tablelands, has one on floats! He flies it from his property there and Lake Tinaroo! Last time I spoke to Bill, he had it registered VH Experimental so that he could keep the third seat in it.
Franco.
One of these was operated by a company which made a film using one of those really big Cine-Max cameras. It came into Camden for servicing a few years ago.Seen from a distance, the Aircam is reminiscent of a 1920s Handley-Page airliner.
[ATTACH=full]47690[/ATTACH]
OME
It has roughly the same performance as the Handley Page Airliner, admittedly they took up a little more aerial real estate ;-)
An agent at Oshkosh told me that you must have a twin endorsement in the USA. However the Aircam has minimal asymmetric thrust an will take off from water on one engine if needed.
$65,000 USD for a kit with no engines?Gotta be keen.
If you can afford two Rotax 912's I guess the kit price won't put you off.
If you want to see a Drifter on Steriods, check out this Pterodactyl ;-)http://www.worldaircraftco.com/surveyor/
That'll be a really good aircraft I reckon. A good replacement for the old Drifter, now with a 912, better landing gear, and durable all metal structure. That's designed by Max Tedesco who also designed the MXP 740, since copied by ICP and renamed the Savannah. He has long experience designing and building practical ultralight aircraft.
JG
I agree re the WAC Surveyor, noticed these a couple of years ago but don't seem to have 'taken off' as yet. Video review follows.
That` about it!.... Always comes down to what the individual want`s and how much money there is to play with!... Certainly heading back to a rich mans sport!
