DGL Fox Posted January 28, 2017 Posted January 28, 2017 Hi All, Does anyone have one of these for sale AVIASPORT ROTAX 912 TACHOMETER - 3-1/8 in..... or know where I can buy one, thanks. David
cscotthendry Posted January 29, 2017 Posted January 29, 2017 Dave: I'm assuming you've tried Floods? Failing that AVIASPORT ROTAX 912 TACHOMETER - 3-1/8 IN. from Aircraft Spruce OR with built in hour meter AVIASPORT ROTAX 912 TACHOMETER / HOURMETER - 3-1/8 IN. from Aircraft Spruce
DGL Fox Posted January 29, 2017 Author Posted January 29, 2017 Dave:I'm assuming you've tried Floods? Failing that AVIASPORT ROTAX 912 TACHOMETER - 3-1/8 IN. from Aircraft Spruce OR with built in hour meter AVIASPORT ROTAX 912 TACHOMETER / HOURMETER - 3-1/8 IN. from Aircraft Spruce Hi Scott, Yes I know they sell them but I was hoping someone might have one second hand, maybe updated to a glass panel but yes I guess Bert Flood would be my other option... David
Mick Posted January 29, 2017 Posted January 29, 2017 What has happened to the old one? The VDO one in my Sportstar had the LCD screen for the hour meter fail. I took it out & had the LCD screen replaced. The time was still counting accurately even though the screen would only display intermittently.
DGL Fox Posted January 29, 2017 Author Posted January 29, 2017 What has happened to the old one?The VDO one in my Sportstar had the LCD screen for the hour meter fail. I took it out & had the LCD screen replaced. The time was still counting accurately even though the screen would only display intermittently. Mick, Mine has the small 2in taco in the panel on the right side and I would like to put the bigger one into the main area in panel..the small one is hard to see as the increments are very small... David
Mick Posted January 29, 2017 Posted January 29, 2017 Mick,Mine has the small 2in taco in the panel on the right side and I would like to put the bigger one into the main area in panel..the small one is hard to see as the increments are very small... David David is your Sportstar registered LSA? If so you will need approval from Evektor to make the change. As I mentioned my Sporty has the 3 1/8 VDO tacho fitted from the factory so that might be their preffered tacho. I know what you mean about the small one, my firt Sporty had that. Cheers!
