Steve Neal Posted February 13, 2017 Posted February 13, 2017 OOPS posted in the wrong spot, please have a look at general discussion if you have any ideas on oil temps on Jab powered Supapups or Aeropups, thanks Steve .
horsefeathers Posted February 14, 2017 Posted February 14, 2017 Sounds just about perfect temps (80 - 90 deg C) to me. You need those temps to remove any water that's condensed into the oil when it cools after running. They are the sort of temps my Jab 160 / 2200 oil runs at, and I wouldn't want them any lower than yours.
Steve Neal Posted February 14, 2017 Author Posted February 14, 2017 Sounds just about perfect temps (80 - 90 deg C) to me. You need those temps to remove any water that's condensed into the oil when it cools after running. They are the sort of temps my Jab 160 / 2200 oil runs at, and I wouldn't want them any lower than yours. Ok thanks just thought it seemed a bit high compared with my old SK Jab, guess I'll just keep an eye on it. Summer is almost over now so I probably have a bit of time to work things out, she's only got 50 hrs on the clock so things are also probably a bit tight also. Steve.
