Hi all,
was just wondering if a 2 axis pilot (TruTrak for example) can be install in a Savannah ?
If so what brand and what servo should be used ?
Cheers,
Xavier
I think that new one that uses the high power model servos as antibalance tabs would be the go...its by trutrak as well..also much much cheaper
I looked at the Gemini Eco but it doesn't look like they are selling them anymore.
A mate of mine is installing a Gemini AP on his Texan and it was very affordable, just don't know if the servos are compatible with the Sav setup
Hi all,was just wondering if a 2 axis pilot (TruTrak for example) can be install in a Savannah ?
Cheers,
Xavier
I installed a 2 axis a/p using MGL xtreme plus mgl servos. Fair bit of work to make brackets and install. I wasn't super happy with the residual drag of the servos, that is the amount of drag on the controls when the a/p is disconnected, but it appears you do get used to it.
You can use other servos with the MGL system and I have heard of servos with nil residual drag.
I did look into the Eco system from tru track, looks good and easier to install and nil drag on the controls but try and get info out of them is like pulling teeth, I gave up.
Rick
Thanks Rick for the info,
I received a response from TruTrak about the ECO :
"Unfortunately, the ECO is not yet available. While we work on obtaining STC approvals for our Vizion autopilot the development of the ECO has been put on hold. I do not have a time frame for when we’ll be able to resume work on it right now. "
I reckon I will wait to see what's happening with ECO in the next 12 months, I am not really keen on installing the full big setup.
Cheers,
Xavier
I think the Eco would be just the ticket....its also I believe a lot safer than the std autopilots setups as you can override a faulty servo and lets face it really you just want it to take away most of the work to let your hands free for a while to do other stuff. Also I really like the overshoot programming they have in it...would be great for low time pilots to stop stalling in turns on final
  • 3 weeks later...
I see trutack have removed the Eco from their product list, disappointing.
  • 11 months later...
I am in process to install Dynon EFIS D10A with AP74 and SV52 servos. My Idea is to install the servos as per below photo. Any comments will be much appreciated.
  • 2 months later...
  • 3 weeks later...
Bummer....I wonder what the issue was....maybe thats a project I need to look at in the future. We have the technology
So how is your prototype coming along?
  • 1 month later...
Steve...too many prototypes around the workshop now...maybe when i get a few of them squared away
Belite are using a linear servo for pitch control...... RADIANT Pitch Trim System - Belite Aircraft
I wonder if something like that could be developed to maintain altitude automatically.
I have a cable/spring control on my elevator trim tab. I've thought about one of these linear servo's spliced into the cable.
That way it would still give me manual override to some degree. ......
Linear actuators like that would not be fast enough for the reactions required. Fine for trim and flaps but not for anything else...they are too slow
