scre80 Posted April 19, 2017 Posted April 19, 2017 Hi All, I have purchased a AvMap Ultra EFIS after many months of thinking about it. Will start installing it tomorrow. Will let you all know what it is like and how well it functions. Ultra EFIS 1
rmorton Posted April 19, 2017 Posted April 19, 2017 I look forward to that, I have considered them as they to have a good reputation although old technology(like me).
cscotthendry Posted April 20, 2017 Posted April 20, 2017 I have an AvMap GPS installed from new in my airplane. I've had some issues with it. Their software seems a bit buggy to me, but their tech support are very friendly and help as much as they can.
scre80 Posted April 20, 2017 Author Posted April 20, 2017 Installed, and tested on the ground. Tomorrow is the compass calibration and test flight. 1
skippydiesel Posted April 20, 2017 Posted April 20, 2017 Installed, and tested on the ground. Tomorrow is the compass calibration and test flight. I have had the Ultra EFIS in my aircraft for about two years now - no real problems. Some of the function displays are a bit small, for my aging eyesight, to be really useful. It would be great if the AH could be calibrated in the air, when level flight has been established. I found the calibration of compass (4 points rather than two) at flight attitude to be a pain the the proverbial. Much jacking and swearing.
scre80 Posted April 21, 2017 Author Posted April 21, 2017 I have had the Ultra EFIS in my aircraft for about two years now - no real problems. Some of the function displays are a bit small, for my aging eyesight, to be really useful.It would be great if the AH could be calibrated in the air, when level flight has been established. I found the calibration of compass (4 points rather than two) at flight attitude to be a pain the the proverbial. Much jacking and swearing. Well I went to calibrate the compass, it said it passed but it seems not as it is still saying COG. Did you have to do it a few times and any advice? Figured already it is a 2 person job. 1
skippydiesel Posted April 21, 2017 Posted April 21, 2017 Well I went to calibrate the compass, it said it passed but it seems not as it is still saying COG. Did you have to do it a few times and any advice? Figured already it is a 2 person job. Yep! definitely a lot easier with two or more people. If I remember correctly it took me (& my son) several goes to get it right. I think the first attempt(s) were a little to influenced by GA "swinging the compass" technique. Unless later models have changed, the Ultra required "zeroing" on each of the 4 cardinal points with the aircraft at or near, level flight attitude. I established my AH level flight attitude first - then calibrated my compass well away from any ferrous structures and with all my electrical systems turned on. In the end we did the unmanly thing and followed the instructions to the letter. Got the desired result. Good Luck! 2 1 1
scre80 Posted April 21, 2017 Author Posted April 21, 2017 Yep! definitely a lot easier with two or more people.If I remember correctly it took me (& my son) several goes to get it right. I think the first attempt(s) were a little to influenced by GA "swinging the compass" technique. Unless later models have changed, the Ultra required "zeroing" on each of the 4 cardinal points with the aircraft at or near, level flight attitude. I established my AH level flight attitude first - then calibrated my compass well away from any ferrous structures and with all my electrical systems turned on. In the end we did the unmanly thing and followed the instructions to the letter. Got the desired result. Good Luck! Thanks for that. We followed the instructions but seems it did not take. Further reading says it can take a few goes. SO back to the airfield for another go. Also out of interest, did you purchase an updated POI database? or do you use the HSI?
skippydiesel Posted April 21, 2017 Posted April 21, 2017 Thanks for that. We followed the instructions but seems it did not take. Further reading says it can take a few goes. SO back to the airfield for another go. Also out of interest, did you purchase an updated POI database? or do you use the HSI? Yes I did get the update.
cscotthendry Posted September 21, 2017 Posted September 21, 2017 I've now been working with the AvMap tech support people for about 18 months and they still haven't sorted out the heading freeze issue. It appears to me that the AvMap EKP is just a program running on Windows CE and using third party external antennas. The system is buggy and doesn't work particularly well. They seem to be trying to pin the problem on the external antenna, but they don't seem to know what it is. Do yourself a favor, don't buy an AvMap GPS. 1
scre80 Posted September 22, 2017 Author Posted September 22, 2017 I've now been working with the AvMap tech support people for about 18 months and they still haven't sorted out the heading freeze issue. It appears to me that the AvMap EKP is just a program running on Windows CE and using third party external antennas. The system is buggy and doesn't work particularly well. They seem to be trying to pin the problem on the external antenna, but they don't seem to know what it is.Do yourself a favor, don't buy an AvMap GPS. After using the AvMap EFIS for 4 months, very happy with it. 1
skippydiesel Posted September 22, 2017 Posted September 22, 2017 Had my AvMap EFIS for about two years+. No probems. Setting up the cumpass was a pain in the arse, but once done seems okay.
scsirob Posted September 30, 2017 Posted September 30, 2017 My AvMap EFIS has been running fine for 1.5 years. Never bothered to set up the compass, got a magnetic one anyway. Also had an AvMap V GPS. Buggy software, froze mid-air with no way to reset. Returned it for refund.
Garfly Posted September 30, 2017 Posted September 30, 2017 I think the main use of the electronic compass is to enable real-time winds-aloft display. (And probably very much worth the effort.) Otherwise, I can't think of a practical use for electronic HDG when you've already got reliable TRK.
Kyle Communications Posted October 1, 2017 Posted October 1, 2017 My AvMap EKP V works fine and I have the optional AHRS for it and it works perfect as well
cscotthendry Posted October 1, 2017 Posted October 1, 2017 My AvMap EKP V works fine and I have the optional AHRS for it and it works perfect as well Around the local area the EKP works as advertised. On long trips is where things start to go wnorg. After 1-1/2 - 2 hrs, the update of the heading line starts to slow down. It gets to where it updates about every 2-3 minutes! In two minutes I can do a standard rate 360 and the poor old GPS is none the wiser. At this point the heading appears frozen and shows why you shouldn't rely on GPS for navigation cross country. I never had problems like this with my previous GPS. I've had other problems with this GPS also, where it allows settings that either conflict with other parameters and settings or that shouldn't cause problems. One of those is the WAAS/EGNOS setting. If you set this to ON in Australia, it causes the GPS to lose lock on the satellites all the time as it searches the signal for the correction info, that is not available here. WAAS/EGNOS relies on ground stations transmitting correction data to the GPS satellites, which then send a corrected signal to your GPS. We don't have them in Oz (to the best of my knowledge) and so the GPS should ignore or not allow that setting here ... but it doesn't. Another minor annoyance is that in parts of Europe (where these GPS are made) airport codes start with "L". So when you do a search for an airport, to set up a flight plan, the default starting letter is "L" so you have to scroll the thumbwheel around to "Y" which our airfields start with every time! I haven't found a way to change this default behavior yet. It's just stuff like that, that bug me with this thing. When I'm concentrating on flying the plane, little irritations like these get magnified and they add up.
Kyle Communications Posted October 1, 2017 Posted October 1, 2017 I will keep an eye on mine and see.....Its not my primary Nav instrument so good info...will check it out
Nobags Posted February 25, 2018 Posted February 25, 2018 Anyone added a different database to the other than the Jeppersen one? AvMap Ultra EFIS Love to buy one but the HSI Page is not what I want. Just imagine if it had a map and oz runways on it ..... yohooo!
scre80 Posted February 25, 2018 Author Posted February 25, 2018 Anyone added a different database to the other than the Jeppersen one?AvMap Ultra EFIS Love to buy one but the HSI Page is not what I want. Just imagine if it had a map and oz runways on it ..... yohooo! I don't use hsi page that much, more my backup if ozrunways iPad and phone stop working, and paper map lost!! 1
Nobags Posted February 27, 2018 Posted February 27, 2018 I don't use hsi page that much, more my backup if ozrunways iPad and phone stop working, and paper map lost!! That’s my point if the HSI Page was improved to be able to download Ozrwys or other I’d be in there quicker than flesh Gordon!
scre80 Posted February 27, 2018 Author Posted February 27, 2018 That’s my point if the HSI Page was improved to be able to download Ozrwys or other I’d be in there quicker than flesh Gordon! For a low cost EFIS, it is fantastic. If you want more integration and features, then expect to pay tons more $$.
Nobags Posted February 27, 2018 Posted February 27, 2018 For a low cost EFIS, it is fantastic. If you want more integration and features, then expect to pay tons more $$. Happy to pay a bit more. HSI’s are so out of date. I want the AH function and a decent nav function on the next page.
scre80 Posted February 27, 2018 Author Posted February 27, 2018 Happy to pay a bit more.HSI’s are so out of date. I want the AH function and a decent nav function on the next page. If you have the $$. I have my ipad mounted right next to efis, so no real need for me to think about that. Seems I don't have an appropriate pic to share. But if you want one, will see if I can get one. 1
scsirob Posted February 27, 2018 Posted February 27, 2018 Happy to pay a bit more.HSI’s are so out of date. I want the AH function and a decent nav function on the next page. If you want moving maps, they exist. It's called Dynon, MGL or Garmin, and costs accordingly. Or an iPad or Android-based software solution Even Avmap have a moving map (EKP-V), and it offers many of the HSI functions that the UltraEFIS has. For more $$$ and unfortunately not so stable.. The UltraEFIS works as designed. Low cost, many handy functions. You can insert your own waypoints including runways. Great backup for whatever GPS moving map you have available. It now offers NMEA out, which I use to feed into a PilotAware anti-collision device.
Nobags Posted February 27, 2018 Posted February 27, 2018 If you want moving maps, they exist. It's called Dynon, MGL or Garmin, and costs accordingly. Or an iPad or Android-based software solutionEven Avmap have a moving map (EKP-V), and it offers many of the HSI functions that the UltraEFIS has. For more $$$ and unfortunately not so stable.. The UltraEFIS works as designed. Low cost, many handy functions. You can insert your own waypoints including runways. Great backup for whatever GPS moving map you have available. It now offers NMEA out, which I use to feed into a PilotAware anti-collision device. I was thinking about putting it where the alt is now then putting the alt where the vsi is. Little room for iPad unfortunately, currently I use iPhone 8+ with ozrunways for nav. (In a holder over the ign key,not shown) My mates are always cautioning me about how unstable iPhone/iPad can be as sole nav platform.
