Talk about being at the right place, at the right time!!!!
A small plane crashed in flames at Mukilteo Boulevard Southwest in Mukilteo, Washington, on May 2. Dashcam footage shows the plane coming down over the street. A number of cars were damaged, but local reports said there were no serious injuries.The single-engine plane crashed at around 3.40 pm local time, shortly after it took off from Paine Field airport, not far from the crash site. The footage shows the plane hitting some power lines on its way down, which caused a brief power cut in the area, the Snohomish County Public Utilities District said.
[MEDIA=liveleak]f50_1493798704[/MEDIA]
wow - so they were full of fuel and all of that was expended in the air behind the aircraft, after hitting the power lines and the light pole
so by the time the aircraft came to a stop on the ground there was no fire and they just stepped out onto the street...
gives new meaning to the term "dump and burn" don't it ?
be buying a raffle ticket, I would...
wow - so they were full of fuel and all of that was expended in the air behind the aircraft, after hitting the power lines and the light poleso by the time the aircraft came to a stop on the ground there was no fire and they just stepped out onto the street...
new term "bump, dump and don't burn" ??
