For any of you tail-wheel pilots here I welcome some feedback on my Universal Maintenance Free Tail-wheel.
Specifications are:
CNC machined 6061-T6 billet Torsion block and axle with polyurethane compression bars
CNC machined 6061-T6 billet wheel cheek plates
316 stainless steel mounting shaft
2 x sealed 316 stainless steel case bearings with ceramic balls for pivot in torsion block
All bolts are 316 stainless steel
6" x 1-1/4" pneumatic wheel with 2 x sealed 316 stainless steel bearings and black alloy rim
Total weight as shown in photo is 1.68kg
Graeme
  • Like 5
Hi Geoff,
It could be used as a castering tailwheel if that is what people want, but there is no breakfree; because of the design, there would be no reason for it.
Looks very well engineered.
Dare I ask how much it costs, inc shipping?
Why is there no need for the break free?
I am having trouble visualizing how it attaches to the aircraft. Is the torsion block an alternative to the tailwheel spring?
In my opinion break free is a requirement if at all possible. There can be very high side loads on the structure if the wheel cannot break free. It was enough on my Corby to break the structure holding the tail wheel spring.
Are ceramic balls going to be ok with shock/inpact loading?
Are they standard ball races. You can get the ones designed for side/axial loading.
Angular contact ball bearing.
May be some figures on flex with weight loading. Are the designed for GA or Rec?
They look a bit heavy duty for Rec but I'm not a tailwheel pilot.( maybe the pics make it look bigger than it is)
C/S bolts into threadded holes would give it a cleaner, smooth look....
Wouldn't have the nylok then, but that's what loctite is for...003_cheezy_grin.gif.c5a94fc2937f61b556d8146a1bc97ef8.gif
Why is there no need for the break free?I am having trouble visualizing how it attaches to the aircraft. Is the torsion block an alternative to the tailwheel spring?
This tailwheel is designed for Recreational aircraft only
Mounting plate/block is drilled and bolted to match existing tail spring holes
Torsion block replaces the need for a tail spring, chains and tension springs
228790229_Tailwheelmockupwithtorsionblocka2b.jpg.a071a5afbfffcd4ecff49a3fc6923f7a.jpg
