Hi all,
Just installed a Becker 4201 into my home built. During power on testing the units led continuously flashed low voltage and shows 7volts.
Voltage check on battery end shows 13v, same as volts on the pins on radio plug.
Anyone had similar problems? Solutions? Hoping maybe it's just pins the need some contact cleaner on them.
Thanks
  • 4 weeks later...
Hi all,Just installed a Becker 4201 into my home built. During power on testing the units led continuously flashed low voltage and shows 7volts.
Thanks[/quote
Wondering if you've solved the problem? Thanks, Bill
No still faults. Becker said to send it away as it may be a internal failure. Will cost a fair whack to fix it, I purchased it second hand with the description of it working fine.
