skippydiesel Posted June 19, 2017 Posted June 19, 2017 Hi All - Rotax used recommend Castrol Anti-Freeze Anti- Boil Concentrate at 50:50 . Rotax viewed this concentrate as being a formulation "low in silicate and free of nitrate". I have run out of the supply that I had on hand and now find that the above product is not being stocked by my supplier. Questions; 1. What is the name of the current Castrol substitute for the above? 2. What concentrate are most Rotax 912 drivers using? 3. I have access to a supply of reverse osmosis (RO) water - is this okay to use? 4. Or should I go out and purchase deionised water? 5. Or Distilled water?
facthunter Posted June 19, 2017 Posted June 19, 2017 That product is no longer made. I use Pureau mixed with coolant. The coolant of your choice. It's like having a degree in organic chemistry to work out what to use. Water cools better than glycol so use minimum % that works . Keep the makers (coolant) mix ratio as a minimum as below that it doesn't do the right thing corrosion wise. Some coolants use a test strip to check when to change or add concentrate. Nev
corvairkr Posted June 19, 2017 Posted June 19, 2017 I use Nulon premix.You can pick it up from Supercheap. https://www.nulon.com.au/products/Cooling_Systems/Blue_Long_Life_Premix_Coolant Jason
alf jessup Posted June 19, 2017 Posted June 19, 2017 I just use Evans NPG and have so for the last 10 1/2 years with my trike (6)and the Tecnam (4 1/2) (912 4 strokes) Never an issue and never a problem and best of all never have to change it
onetrack Posted June 19, 2017 Posted June 19, 2017 If your heart is set on Castrol products (which I have little time for), then the current Castrol coolant additive is Castrol Radicool. It's available from Sparesbox on eBay or directly from the Sparesbox website. Castrol Radicool Coolant Concentrate 2.5L 3 Box 3377732-BOX3 Radicool is a current-technology low silicate, OAT (Organic Acid Technology) coolant additive, and its "mixture of monoethylene glycol and selected chemical agents, contains no nitrites, amines or phosphates". Keep in mind, it is an additive with a need to mix 50-50 with distilled water - and it's only good for 4 years (there's some conflicting info here - I also found a Castrol specification sheet that says 3 yrs lifespan). Never mix coolant brands, types or colours - always flush the system thoroughly before coolant replacement. Personally, I've yet to find anything to beat genuine Toyota long-life premixed coolant. It's good for 8 years - and it's also low-silicate, OAT, and nitrite, amine and phosphate-free. EDIT - I just noticed that the Castrol Anti-Freeze, Anti-Boil product is also still available on eBay. So either it is not obsolete, or someone is selling old stock. Castrol Coolant Concentrate 2.5L x 3 Packs each makes 7.5 L anti-freeze/boil | eBay
Downunder Posted June 19, 2017 Posted June 19, 2017 I'm about to move to Radicool. I'm told it is more suitable for aussie conditions where as some others are more "european" in their design. Meaning a larger focus on cold temps (anti-freeze) rather than our hotter summer temps found here..... One Rotax user told me he dropped 5 deg c from the previous brand which is what I'm looking for. Radicool can be purchased premixed....no need for water. Castrol Radicool Coolant Premix 5L 3377804 | eBay Evans coolant is no longer recommended by Rotax. Not saying you should change from it, but I wouldn't change to it.
Mick Posted June 19, 2017 Posted June 19, 2017 A phone call to Bert Flood's will give you the correct product recommended by Rotax.
alf jessup Posted June 19, 2017 Posted June 19, 2017 I'm about to move to Radicool.I'm told it is more suitable for aussie conditions where as some others are more "european" in their design. Meaning a larger focus on cold temps (anti-freeze) rather than our hotter summer temps found here..... One Rotax user told me he dropped 5 deg c from the previous brand which is what I'm looking for. Radicool can be purchased premixed....no need for water. Castrol Radicool Coolant Premix 5L 3377804 | eBay Evans coolant is no longer recommended by Rotax. Not saying you should change from it, but I wouldn't change to it. Downunder I believe it is not recommend for the later model 912 engines with the redesigned heads Rotax years back advised not to use 50/50 mix and switch to Evans which I did I personally think they recommend whoever is paying them the most to run their brand of coolant in their engines I have had not one ounce of trouble in the combined 1100 hrs of use with 4 stroke Rotax engines using Evans and I'm not about to change at this point in time Cheers Alf
corvairkr Posted June 19, 2017 Posted June 19, 2017 Here's the latest SI for the selection of suitable operating fluids. https://legacy.rotaxowner.com/si_tb_info/serviceinfo/si-912i-001r3.pdf Jason
Sav 4352 Posted June 19, 2017 Posted June 19, 2017 Been using Castrol anti freeze- anti boil then Radicool since it changed it's name in the same engine for 13 years with no problems so will stick with it. Change it every 2 years. Repco will order it for me but Autobarn usually have it in stock. 1
Downunder Posted June 19, 2017 Posted June 19, 2017 Yes, you're correct Alf as per the SI. New heads only. However I don;t know the age of Skippy's engine so was just putting the info out there. When did they start with them heads? 2013? Must be starting to get a few about.... My friends CT runs very nicely with the evans... Some really good info on the last page of the SI...... all Rotax owners should be aware of... 1
facthunter Posted June 19, 2017 Posted June 19, 2017 There's been extra information out on Evans. The engine does run hotter with it as it doesn't move heat as well as water but can safely run hotter without steam hotspots. Check that it's really suitable for your particular application..The product I was referring to was the 400 mm concentrate Castrol cans that I used for years. 3 did 15 litres. Caltex made an equivalent and I bought a lot of those in bulk but again that product has been superseded. They are not really an antifreeze as they don't have enough glycol % to have much effect inthat regard. Glycol gives anti freeze function but has it's own problems. It leaks out of the tiniest places and doesn't help removing heat as well as water by itself. It can also go off and cause corrosion. As said, DONT MIX Brands or types. It's a dog's breakfast this area now. If you mix your own use pure water with no mineral content in the right ratio as specified on the product. Less than specified may render the effect nullified. It's also expensive. If you look at the cost of the chemicals used to make this stuff you will see how you are being ripped off. Bit like all "oil" products for automotive use today. Nev
flyhi Posted June 19, 2017 Posted June 19, 2017 Castrol Radicool concentrate is usually available at most BP service stations.
alf jessup Posted June 20, 2017 Posted June 20, 2017 Nev I like that the Evans makes it run warmer My heads now run at 95 and the oil came up 10 deg as well Gained 30 deg on the heads from the glycol mix which used to run at about 65 Never had the heads or oil temp ever go out of the green even on a 40 deg day on a prolonged climb to altitude Alf 1
skippydiesel Posted June 20, 2017 Author Posted June 20, 2017 OKAY - done a bit more research : Castrol advise: "Radicool Concentrate" is a direct replacement for "Anti-Freeze Anti-Boil (AFAB) Concentrate" Both Radicool & AFAB contain low (?) levels of silicate and use nitrites as an anti corrosion agent. Further - the nil nitrite specification is not out of concern for the engine but a European concern for nitrites entering the environment ie a pollution issue. (My words - for those that insist on the nitrite free coolant -) Castrol have a nil nitrit coolant available "Radicool NF" specified for European cars (eg Mercedes). The NF may be hard to find and come in a larger minimum quantity than you want. Bert Flood advise: "Radicool Concentrate" is a direct replacement for "Anti-Freeze Anti-Boil (AFAB) Concentrate" My own feelings on coolant choices recommended by Rotax: Evans I have never used Evans - however Rotax advise a lower thermal efficiency than glycol mix and on no account can it be mixed/contaminated with even a small amount of water/glycol coolant. I also believe Evans to be considerably more expensive than conventional glycol coolant. Its main benefit seems to be indefinite in service life. Sooooo - A change to Evans would require a cooling system flush to remove all traces of glycol/water coolant. I have to change rubber every 5 years, this will inevitably result in some loss of coolant and the danger of contaminating the saved coolant. Purchasing top up coolant and filtering of old coolant seem to be likely scenarios - Cost Mess & Extra Time Loss of coolant while away on a trip would be a serious problem - cannot top up with glycol/water. On balance I prefer to stick with the Castrol coolant that appears to have given my engine good service for nearly 800hrs/17 years. Castrol Concentrate (and any other Rotax compliant glycol coolant) I use it at the recommended 50:50 ratio, as I have always done in my land based vehicles. I believe this gives me: A cost effective coolant That gives good increased boiling point and anti freezing (not so important in our climate) qualities ie good thermal characteristics. Anti corrosion qualities to protect the internals of the cooling system. Lubrication of seals Maximum time of in service life (see manufacturer's recommendation) Is widely available, should a top up be required (touch wood - never happened). I would not use a pre mix as they are usually at a lower than 50:50 ratio nor would I mix the concentrate at less than the Rotax recommended ratio as I feel that some of the benefits listed above would be diminished.
onetrack Posted June 20, 2017 Posted June 20, 2017 You've nailed all the pertinent points very well, with a great deal of thought. The point about being able to refill/top-up in case of coolant loss, when a long way from home, is very important. The latest OAT coolant technology is very good. The important thing is taking notice of the manufacturers advice, because they alone know the precise composition of the alloys they use. There are a multitude of alloys utilised today, and with multiple components, often utilising different metals, electrolysis is always ready to rear its ugly head. There are also recommendations from coolant manufacturers to check for stray electrical discharge through the radiator, which can accelerate electrolysis caused by dissimilar metals in contact with coolant.
crashley Posted June 20, 2017 Posted June 20, 2017 http://legacy.rotaxowner.com/manuals/tr-im-912-001-r1.pdf
IBob Posted February 12, 2019 Posted February 12, 2019 First new engine run not tooooooo far off now. Time to be sourcing various vital liquids. And this site continues to give a wealth of practical information. Thanks to all.
Blueadventures Posted February 12, 2019 Posted February 12, 2019 'Castrol Radicool' is what I use; no issues. Read mix ratio. Eg not more than 50% in concentration for Rotax 912 uls. Cheers 1 1
facthunter Posted February 12, 2019 Posted February 12, 2019 A High % of Glycol gives less heat transfer compared to straight water. In the 912 I don't think it's as critical as some other motors. Use pure water with your mix if you use concentrate. I use Pureau. it doesn't cost a lot in say 5 litre casks. Corrosion inhibitor alone with water has worked OK in the past but is not available with many brands now. Modern coolants can be tested with a strip and topped up with strong stuff. If there's seepage of combustion products into the system it will be degraded and cause corrosion. This could be a head gasket "O" ring or metal porosity. and requires a system flush and replenish . Try to combine it with your hoses change. Check your pressure cap seal . Your plane does fly up high sometimes and lower pressure means lower boiling point. It's the actual pressure . Not the differential pressure.Nev
planesmaker Posted February 12, 2019 Posted February 12, 2019 Nev 912’s don’t have head gaskets. The coolant does not go past any gaskets except the o rings on on inlet and outlet pipe of each head and on water pump.
Downunder Posted February 12, 2019 Posted February 12, 2019 First new engine run not tooooooo far off now. You may be aware, but Rotax came out with a new oil purge procedure last year for new engines and engine that have had the oil system drained. https://legacy.rotaxowner.com/si_tb_info/serviceinfo/si-912-018r2.pdf 1
facthunter Posted February 12, 2019 Posted February 12, 2019 My reply is not just about Rotax. 912's The 582 runs O rings I think and there are other auto engines it applies to Like Suzuki ,Honda Subaru that run gaskets. that deteriorate and seep . Nev
IBob Posted February 13, 2019 Posted February 13, 2019 Downunder, I had seen that, but only in passing. I find I have tended to focus mainly on what comes next, rather than All Of It with the build: less than ideal in some ways, but All Of It has sometimes felt overwhelming. But what comes next will be the first runup in a couple of weeks. So time for me to focus on that, and thanks for the reminder. 1
